Burning coolant
  • kwill22
    • Apr 2009
    • 962
    Burning coolant
    I go to start my car Monday and it cranks 1 time the cuts out like the starter stopped. Then I cranked it again and it cranked about 3 times before cutting out again. Third time I tried it started fine but was burning coolant. White smoke and everything. Smoke stopped when the car warmed up. my car had no symptoms or issues before this time.
    It was dark so I said I'd deal with it Tuesday. Went out and it started fine. No smoke no coolant smell no nothing. So I drove it to work with no issues and after work gave it a compression test and filled and bled the coolant. Still no issues. Compression was 170-180-181-180. Coolant reservoir did bubble when holding the throttle.
    So today to go to crank it up and it cranks 2 times and on the third crank it sounded like it missed or just had a hard crank and cranked 2 more times and did the hard crank again the started fine. Had smoke again this morning until it warmed up and the smoke went away.
    I have no mixture of coolant and oil either when I checked yesterday. I would think I have a gap or something somewhere that seals up when the engine heats up but that doesn't explain yesterday's cold start when It started just fine. I got a head gasket tester and gonna check to see if its exhaust coming into the coolant system today after work. Also car doesn't overheat.
    Anyone have any ideas. Thanks in advance!
    PS. Also replaced the head gasket and various other things about a year and a half ago. But DIDNT resurface the head. Dumb yea I know but nothing I can do about it now.
    DENY IGNORANCE!
    Schwarz 325-totaled
    brilliantrot 318i-daily
    Originally posted by mkcman17
    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
  • kwill22
    • Apr 2009
    • 962
    I live in an apartment so no compressor to do leak down
    DENY IGNORANCE!
    Schwarz 325-totaled
    • Dj Buttchug
      • Jun 2010
      • 7686
      if you didnt resurface chances are the job is going to have to be done again correctly. It sounds like the HG is leaking at certain engine temps and sealing when hotter.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • kwill22
        • Apr 2009
        • 962
        That's what I think I will end up doing. I used a tester to check if exhaust gases where escaping through the coolant overflow and it never register exhaust gas. Just to be sure I held it to the actual exhaust and it turned yellowish/green so it registered.
        Well looks like I'm pulling the head this weekend.
        DENY IGNORANCE!
        Schwarz 325-totaled
        • kwill22
          • Apr 2009
          • 962
          Called the shop and if I can bring it in the morning they can have it done by the afternoon.
          Question is should I go ahead and take the cams and valves out or can I turn the cams to where the valves won't interfere with the process
          DENY IGNORANCE!
          Schwarz 325-totaled
          • Dj Buttchug
            • Jun 2010
            • 7686
            remove the complete valvetrain before you cut the head. the cams valves and springs all have to come out.
            You can pull the cams easy. If the machine shop you are taking it to knows what they are doing they will remove the valves for you before they machine it.
            Ig:ryno_pzk
            • kwill22
              • Apr 2009
              • 962
              Yea. I was trying to avoid having to pay them for it when I can do it myself. Since I'm doing everything else. Thanks for the input
              DENY IGNORANCE!
              Schwarz 325-totaled
              • roguetoaster
                Biggus Tippus
                • 7830
                If you can get a good set locally it's a great time to do the valve stem seals.
                Further, when I got my cyl head done a couple of years ago in Ocala I removed the cams, but left the valves in, got it tested for cracks, cleaned, machined and reassembled with new stem seals (that I provided) for $120.
                But if you are really hard up you can pull/reinstall the valves yourself with a press, a notched socket, a magnetic pick up tool (for the retainers) and patience in about 30 minutes, just don't lose a finger in the process.
                • kwill22
                  • Apr 2009
                  • 962
                  Yea I've been trying to pop the retainers off but I don't have a notched socket so I can't see what I'm doing ill pro only push down with some lineman pliers and have my wife take the retainer off if I don't have a remover at work.
                  DENY IGNORANCE!
                  Schwarz 325-totaled
                  • kwill22
                    • Apr 2009
                    • 962
                    Heads cracked.
                    DENY IGNORANCE!
                    Schwarz 325-totaled
                    • Dj Buttchug
                      • Jun 2010
                      • 7686
                      fuuuuuuuuuuuu
                      Ig:ryno_pzk
                      • bmwman91
                        • Oct 2004
                        • 3134
                        Is the crack in cylinder 2's exhaust port by one of the valve guides?
                        Transaction Feedback: LINK
                        • kwill22
                          • Apr 2009
                          • 962
                          Yes sir.well it was cracked by cylinder 2 or 3 (have to look at it) coming from a coolant hole. Have one one the way as of today hopefully. I was trying to think of all I could do while I have it apart but no funds at the moment. (Performance wise)
                          DENY IGNORANCE!
                          Schwarz 325-totaled
