M42 COP kit install
  • LoneWolf
    • 402
    M42 COP kit install
    I bought a COP kit second hand, previous owner didn't send the instructions.
    Seems like a simple install just hung up on one thing, the all-thread.
    How are the nylon spacers supposed to go? On top of the nut, under the nut?
    And how did you guys go about torquing it down so you don't get an oil leak?
  • wazzu70
    • Jan 2005
    • 1143
    Put the all thread in where the two center valve cover bolts were. Use the washer from the old bolt to put on top of the rubber grommet. Tighten a nut down on that to the correct torque spec to hold down the valve cover. Put the plastic spacer on the stud above the nut. Put the COP plate on top of the spacer. Add a washer and nut on top of the COP plate.
    Hope that helps. If you have questions I can try to expand further :)
    -Nick
    M42 on VEMS
    • LoneWolf
      • 402
      Huge thanks!
      After taking a break for a bit this is exactly what I ended up doing.
      • wazzu70
        • Jan 2005
        • 1143
        Its always nice to verify you are thinking right!
        -Nick
        M42 on VEMS
        • LoneWolf
          • 402
          Absolutely. The threads for the valve cover bolts strip so easy, last thing I want to do is have to deal with that.
          • wazzu70
            • Jan 2005
            • 1143
            I actually just finished drilling out all my valve cover threads and heli-coiling them for just that reason :)
            -Nick
            M42 on VEMS
            • LoneWolf
              • 402
              Btw your vems m42 thread is going to be a lot of help for me. Looking to go that route soon. Slow because of funds. I have another m42 on an engine stand I plan on rebuilding, towards a turbo build.
              Hoping to use vems on my engine just for testing and have the whole harness modification done before swapping in the rebuilt.
              You have any info on possibly wiring in a knock sensor somehow? I know the last model m44 had one. Could be useful for tuning.
