M42 to m20 no injectors are firing?
  • e30m20TurbO7
    • 1203
    I did a m20 swap on a 318 IS and I'm nt getting any of the injectors to fire, everything else is working. I'm getting spark fuel and the car just cranks unless I spray gas into the engine. What's the x20 pinout on the 325i engine harness compared to 318is
  • TobyB
    • 5265
    search 'c101'- there are some good threads that saved my butt a few years back.
    Depending on the year of your engine, you need to move a wire or 3. If you didn't get
    smoke, it's only one or 2.
    If you meter an injector to a chassis ground with the ignition on, do you have 12v at the connectors?
    That's easy to trace- and not having it seems to be a fairly common problem...
    t
    • Dj Buttchug
      • Jun 2010
      • 7678
      if you have a late model m20 harness there are no c101 changes. Its straight up plug and play into a 318i/is chassis.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • e30m20TurbO7
        • 1203
        Same shit I crossed my lines
