M42 with this Turbo?
  • No Loose Ends
    • Jun 2013
    • 2
    Hey guys im planning a budget Turbo build for my Winter E30 318IS! ~0,8 Bar
    A friend of me got this turbo i can buy very cheap...
    Is it too big?
    http://www.ebay.de/itm/200647188823?...823%26_rdc%3D1
    with modified m50 manifold and so on.
    Thanks for your Infos
    Greetings from Germany
  • TobyB
    • 5286
    Depends.
    It's small (a/r ratio for both sides) for a t3/t4 hybrid, and that, from
    very old memory, seems OK for midrange boost.
    t
    • No Loose Ends
      • Jun 2013
      • 2
      Thanks
      • TobyB
        • 5286
        If you look up the pressure maps, and figure/find the flow numbers for a 4- valve 1.8l.
        then chart where the pressure/volume lines go,
        that will tell you for sure.
        I just remember that, doing that for a 2l 2 valve, a .80 a/r on both sides started to
        build boost at about 2500, and didn't become unstable until 8k. And also didn't
        build more than about 12 psi until 4k or so, which seemed appropriate for an old Volvo
        pushrod engine...
        hth
        t
