Mystery knock
  • M42Power
    • Dec 2009
    • 519
    Mystery knock
    So guys, my m42 as developed a weird knock.
    It only happens with the engine fully warmed up after it idles for a very long time or if i shut it off. After driving around it goes completely away.
    It comes from the head directly above the exhaust valves for the 4th cyl
    I already changed the oil and filter (castrol gtx 10w40) and there were no metal particulate in the filter.
    Here's two videos. The first is after i drove it around and got it warmed up (normal m42 noise with a bit of chain slop me thinks). The second one was taken after i let it sit turned off for 5 mins.
    So, rod kock or lazy lifter guys?
    Originally posted by kendogg
    Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
    OG RACECAR
  • kwill22
    • Apr 2009
    • 962
    The constant noise is deffinately timing chain. Maybe guides or tensioner. Check you can hear teeth.
    The only other noise I hear is right when you hit the throttle and goes away when you let go. Is that it?
    DENY IGNORANCE!
    Schwarz 325-totaled
    brilliantrot 318i-daily
    Originally posted by mkcman17
    don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
    • M42Power
      • Dec 2009
      • 519
      That's the one i'm talking about. The sharp knock
      OG RACECAR
      • EyExR
        • Jan 2011
        • 959
        I don't hear a knock at all....
        My 325iX DIY Threads:
        Front Wheel Bearing Replacement
        325iX Rear Subframe Bushings and MUCH more w/pics!
        325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        • M42Power
          • Dec 2009
          • 519
          It's on the second video, every time i accelerate
          OG RACECAR
          • Dj Buttchug
            • Jun 2010
            • 7688
            timing case brah
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • bmwman91
              • Oct 2004
              • 3134
              Yup, sounds like timing case. Start thinking about getting in there to take a look.
              Transaction Feedback: LINK
              • M42Power
                • Dec 2009
                • 519
                Well, better than a rod knock. Gonna order a tensioner just in case.
                Btw, just to enlighten me, how does trouble in the timing case relates to knocking towards the back of the engine?
                OG RACECAR
                • bmwman91
                  • Oct 2004
                  • 3134
                  Maybe I was missing the knocking sound (watched both videos). It sounds a lot like timing case noise to me. Is it that apparent that it is specifically coming form the rear of the engine when you listen in-person, or did you hold a screwdriver and listen to that to try to pinpoint it?
                  • M42Power
                    • Dec 2009
                    • 519
                    Just listening to it it seems pretty obvious it comes from the back of the engine. More specifically above the exaust valves for the 4th cylinder.
                    Its the sharp knock whenever i accelerate that goes away when i let go of the throttle. (on the second video)
                    Could it be the valves hitting the piston from something loose in the timing chain?
                    OG RACECAR
                    • M42Power
                      • Dec 2009
                      • 519
                      No more feedback?
                      I wanted to know if can keep driving the car or not
                      OG RACECAR
                      • kwill22
                        • Apr 2009
                        • 962
                        the other noise he was talking about besides the timing noise was right when he hits the throttle. at the moment when its about to accelerate its a slight piston slapping sound and it goes away when the engine revs. you havn't overheated your engine anytime have you? thats the only time ive ever heard that noise or the engine is really beat or hasnt been maintained. Definitely have to get on that timing case though.
                        piston to valve noise would be constant and a heck of a lot louder than that.
                        have you checked your spark plugs?
                        DENY IGNORANCE!
                        Schwarz 325-totaled
                        • M42Power
                          • Dec 2009
                          • 519
                          It only happens when i full throttle. I'm mabye thinkining it can be pre-detonation.
                          The plugs seem good. The wires i'm not so sure
                          The engine was slightly overheated for a very short period of time, and that was nearly 6 years ago. The engine has been well mantained so far. Has like 130k miles
                          OG RACECAR
                          • kwill22
                            • Apr 2009
                            • 962
                            Only at WOT, sounds like TPS or o2. The TPS takes over for wot and the o2 is ignored right. Something like the TPS reads WOT and the DME switches to a different map?
                            DENY IGNORANCE!
                            Schwarz 325-totaled
                            • M42Power
                              • Dec 2009
                              • 519
                              My car doesnt have an o2 sensor, so it could be a bad tps. But i'm going to sort out the iginition system first. I think i might order a cop kit.
                              OG RACECAR
