Well...did something stupid today.
  • elbrack
    • Jul 2013
    • 176
    Went around a turn too fast, spun out, and hit a curb. Knocked my lip off and cracked my oil pan. Haven't been able to look at it yet, since I had to be at work. Hoping that it's only the lower pan. Looks liked it got the corner of the pan from what I saw.
    This is a pretty straight forward job though correct? Pull the pan, replace gasket, bolt pan back up.
    Anyways I'll be going a bit slower :-D
  • econti
    • May 2014
    • 1152
    Cracking a pan is up there on my list of shit I don't want to happen.
    Is it easy to get a steel pan made up? Or make it myself?
    • elbrack
      • Jul 2013
      • 176
      Just buy a new one. You can get them for under 100 dollars these days unless you're buying BMW OEM.
      • Roysneon
        • 4505
        I swear I saw new lower pans for sale for like $20-$40 before.
        Originally posted by mbonanni
        I am a pursit now.
        • elbrack
          • Jul 2013
          • 176
          I've seen a few for about 50 bucks. Just praying that it is the only thing I need to repair. :-D
          • kwill22
            • Apr 2009
            • 962
            Yea $50 is the cheapest usable one I've seen.
            I remember the first time I spent out in my E30. Did it on a long sweeping off ramp that suddenly got sharper in the wet with crap tires. And to make it worse I lifted instead of controlling the small slide and just sent my rear end on around. Luckily i had a lot of grass. I had to slowly pull the brake to keep from sliding backwards into a pond. No damage though. Drove right out and back onto the road with mud everywhere. That was the first and Last time I lifted. Lol
            DENY IGNORANCE!
            Schwarz 325-totaled
            brilliantrot 318i-daily
            Originally posted by mkcman17
            don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
            • econti
              • May 2014
              • 1152
              But if you hit it again it'll just crack again. I heard someone say that a steel one won't crack nearly as badly.
              • diamonddonbmw
                • Sep 2012
                • 124
                But..... If the steel one won't crack as badly doesn't that risk damage to aluminum parts above it that might be more costly to replace? Just wondering.
                1991 318is, AWII, Eibach/GC, Koni
                Riverside CA
                • MPLFoster
                  • May 2013
                  • 1490
                  Steel pans tend to dent rather than crack. they'll absorb the impact and transmit less force into other parts. just depends on how hard you hit something with the pan.
                  best just to replace it with an OEM pan and drive carefully.
                  form.follows.function IG @mplfoster
                  • jntar
                    • 459
                    Personally a skid plate and stock pan seems like a better idea than a custom steel pan.
                    M42 turbo build.
                    http://www.r3vlimited.com/board/showthread.php?t=301330
                    • elbrack
                      • Jul 2013
                      • 176
                      Yea, I was looking at the skid plate today and saw 250 bucks for one. YIKES! I'll be driving a bit more carefully after this. Ordered the part. Will probably get around to pulling the pan this weekend. Hoping for no further damage.
                      • elbrack
                        • Jul 2013
                        • 176
                        Anybody know the torque specs on the oil pan bolts? I looked in Bentley, but it wasn't specific about the lower oil pan. I got the car running again on just about a turn or so after handtight.
                        2 bolts decided they wanted to spin around a bit. One stays sorta tight. Not sure why though. Didn't overtorque for sure.
                        • jntar
                          • 459
                          10nm for stock bolts. I have upgraded bolts from fastenal and used 12nm.
                          M42 turbo build.
                          • elbrack
                            • Jul 2013
                            • 176
                            Nice. I'll torque em down before I put the splash guard back on. Thanks.
                            • brianf408
                              • 51
                              The skid plate is well worth it. I would have broken my pan again the day after I replaced it if I hadn't put a skid plate on. Sometimes you just can't avoid debris in the road, best to spend a few bucks and protect the engine.
