What is this wire for?
  • george graves
    • 19997
    Wouldn't it be best (if you had it plugged in) to unplug it, and reset the ecu and let it re-learn?
    Originally posted by Matt-B
    • JNSmith1717
      • Oct 2014
      • 35
      Amazingly my car runs better now
      • DER E30
        • Sep 2013
        • 2349
        So with no cat I should have it plugged in?
        -Christian
        • ck_taft325is
          • Sep 2007
          • 6880
          Presumably.
          Need a part? PM me.
          • roguetoaster
            Biggus Tippus
            • 7830
            As long as you have no O2 sensor.
            AFAIK there is no difference in the DME, as both a "euro" and US version have the same P/N.
            • DER E30
              • Sep 2013
              • 2349
              Hmmm, I'm catless but presumably have an o2 so leave it alone?
              -Christian
              • roguetoaster
                Biggus Tippus
                • 7830
                Yes, since the sensor is pre-catalyst you should leave the wire plugged in if you do have a sensor installed.
                Either look under the car or follow the wire under the battery tray in the engine compartment to the sensor.
                • chodedub
                  • May 2013
                  • 56
                  Originally posted by M3s14
                  I knew this topic would be about this wire / plug...
                  Everything has been said, I will just add this picture, check bottom left
                  Sorry to thread jack, how do you tell which plug goes to which sensor? Trial and error?
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    Look at the lengths of wire/the bends in the wire, that will generally tell you which one goes to the oil pressure sensor and which two go to the head. Then the coolant plugs will be differentiated by the number of "sockets" for pins on the plug itself, as one has two and the other has one. Further, on my cars the forward coolant plug is grey, the aft is black.
                    Thus, of the two black plugs, the two pin one goes to oil pressure, the one pin goes to the orange/red/brown sensor on the head, and the grey plug goes to the blue two pin sensor forward on the head.
                    Got it? Good.
                    If you are working from a wiring harness out of the car I would say to start with a pin out of the DME and then continuity test the plugs.
                    TLDR (if your car is the same as mine):
                    black two pin connector = oil pressure
                    black one pin connector = rear sensor on head, one pin, redish/browinsh in color
                    grey two pin connector = front sensor on head, two pin, blue sensor
                    • bluevanilla
                      • Nov 2014
                      • 16
                      Just checked last night, it was not connected. :up:
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Who are you? Did you have the same problem or did you log in under another name?
                        • bluevanilla
                          • Nov 2014
                          • 16
                          I could have same problem because I have an e30 with m42 engine.
                          • vpilarrt
                            • Jun 2006
                            • 2096
                            No. If you have an O2 sensor you want this wire disconnected.
                            • vpilarrt
                              • Jun 2006
                              • 2096
                              One of the coolant temp plugs has 2 contacts, the other has 1 - so that's easy to fugure out. If you plug the oil pressure connector onto the coolant sensor and visa-versa you will get obviously incorrect engine temp readings and the oil pressure warning light will be on.
