1991 318is has been sitting since 2004
  • Gerta
    • Sep 2009
    • 2119
    Lots of good info here and on M42 club, OP. Post pictures of this diamond in the rough.
    Parts Collector and Former Houndstooth interior junkie.
    • george graves
      • 19996
      Originally posted by mrhassouneh
      either way I'm really not at a loss anywhere so why not
      Lol. Learning by messing things up is always an option! Heck, we've all done it - I don't recommend it - but it's there.
      Find someone local, that can look over things and give you an hour of their time. Buy them a 12 pack. Easy. You'll learn much more. Just my 2 cents.
      Originally posted by Matt-B
      • mrhassouneh
        • Aug 2014
        • 51
        posted a few pics if anyones interested lol and i believe your right about that...might be best since
        i know a few car buds that would really be into helping on this so ill give it a go.. but its become an addiction already lol bought another from the same lady today but its an e34 and I'm hoping maybe a few people could enlighten me as to if i can swap much from one to the other.. only problem is its an automatic
        • roguetoaster
          Biggus Tippus
          • 7829
          Seems like a fairly easy restoration to me. Is that a glass moonroof or just a black painted panel. If the former you just paid for your work/swap/whatever.
          Depends on the E34, generally not much can be used on an E30, however, it potentially has an M30 engine, which is an excellent swap candidate if you go that route.
          • mrhassouneh
            • Aug 2014
            • 51
            its got a sunroof but for some reason its sagging down a little below the roof but I'm not sure how much work it is to adjust and reseal it lol
            • mrhassouneh
              • Aug 2014
              • 51
              and it actually has an m60 motor with the alusil changed block so I'm guessing were on a good start
              • mrhassouneh
                • Aug 2014
                • 51
                Diesel sound now but coming together
                So guys here's a list of what's been done so far (my pockets are starting to hurt and I've got stuck someone help! Lol)..
                I've had it in the shop about a month and have replaced literally everything but the damn motor itself..
                I've had the head machined, the bottom end has awesome compression so I really didn't touch anything else on the bottom end..., bought new plugs,wires, fuel, oil and air filters, new fuel pump, water pump, thermostat all hoses for vacuum and coolant, belts ,new clutch slave cylinder and master cylinder with new hose, all new rotors,pads,lines and sensors, front hubs and rear bearings replaced... Complete bluntech lemmfoerder suspension overhaul kit underneath with a uuc sway bar kit front and back, new strut mounts all four corners, bilstein sport cup kit (not to happy with the height diffrence) motor mounts, trans mount, idler pulley and changed the main relays that where most important and where available for the time being along with all new fuses...
                Here's where my problem is:
                I reassembled everything charged it up and start it up flawlessly... It idles beautifully BUTTT..... I'm now getting this dreaded diesel noise from what seems like one of the cams.. It sounds like it's not getting oil to it properly.. I know it's not timing or the belt skipping a tooth because I had a BMW tech friend of mine around when we checked it..and Im positive the valves aren't bent since they where fine when assembling earlier... Could anyone tell me if maybe the wrong oil could be a factor or maybe since its sat so long I should leave it running a little longer to let it lubricate better? I'm lost and no longer have another hand or knowledgable partner to help until he gets back from his trip in a few months... Lifters seem good also btw before anyone bashes me to READ or use the search bar I've searched for days and nothing quit fits my scenario
                I've put so much into this car I could have probably swapped by now but I'm hoping that somone has been in this situation and might be familiar with a resolution..
                • mrhassouneh
                  • Aug 2014
                  • 51
                  As long as this doesn't all end up going south next step is paint and ready to mount up my new wheels I got and enjoy her for what she's ment to be
                  • G FORCE
                    • Mar 2014
                    • 159
                    Sounds like you have done a tone of work. I was surprised at how much parts are for this little car so I can imagine the amount of money you've dropped already.
                    When you had the head machined, was it just decked? Did you have them inspect it for any damage? How did the cams look?
                    Maybe hook up an oil pressure gauge?
                    Good luck with it and hope you get it figured out and all is well.
                    Gabe
                    '91 318is
