waterpump
  • ///M42 sport
    • 3952
    waterpump
    installing a new waterpump. Is there anyway to prevent it from "sticking" when it comes time to replace it again? I was thinking of putting antiseize on the mating surface?
  • ethrty
    • Nov 2009
    • 342
    not a good idea, can damage the seal. just tap it out when its buggered again, small club hammer, few wacks either side of the part where the pulley bolts on and it will pop off. You cant damage the block, the pump housing will shatter long before that (which would only happen if you are beating the hell out of it)
    • ///M42 sport
      • 3952
      THis is what I found. So I had to swap out the timing case. Obviously the po had a hard time getting the waterpump out.
      • Threehz
        • 1480
        This is not what I wanted to see as I'm about to pull mine.. How did you end up getting it out?
        Different strokes for different folks.
        • ///M42 sport
          • 3952
          since I had a extra timing case ready to swap out, I pounded the waterpump with hammer. That thing felt like it was welded in there
          • Massimo
            • Jan 2008
            • 3207
            I had to pound the pump for 1 and half hours to get her off
            • TobyB
              • 5220
              Yeah- whakketta whakketta whakketta for me, too.
              Back and forth seemed to work best- one side a bit, then the other.
              If you were to use an anti- seize, find something that's rubber- compatible.
              Most is petroleum- based, as ethrty noted, and will kill the seal...
              t
              • mabeer
                • Mar 2012
                • 43
                This works great.
                • bmwman91
                  • Oct 2004
                  • 3128
                  I have used heavy silicone grease on my o-rings for years. It does not harm the rubber, makes stuff go together easier and helps to prevent things from getting stuck. In a pinch you can use silicone dielectric grease, but if you can find the really thick stuff that's even better. Wear gloves though, it is a chore to try to wash the stuff off of your hands since it is so good at resisting water & soap!
                  Transaction Feedback: LINK
                  • cody_eppler
                    • May 2013
                    • 38
                    My dad made me a custom m42 water pump puller. I was trying to get my water pump out for four days. After he made it, it probably took us less than a min to pull it out. If anyone is interested let me know because we can make more of them. It saves to the struggle and wanting to blow up your car.
                    • roguetoaster
                      Biggus Tippus
                      • 7826
                      Struggle is half the fun, and I'm firmly convinced that we wouldn't appreciate our cars as much as we do if we didn't have some difficulties repairing them.
                      • cody_eppler
                        • May 2013
                        • 38
                        I agree! Ive only had my 318 for a little over a year. I didnt know much about cars before i bought it. Now im doing my head gasket and waiting on parts to put it back together. Its a great car and it just makes you love it that much more.
                        • Threehz
                          • 1480
                          I'm getting all warm and fuzzy about doing my timing and cooling STOP IT GUYS!
                          Honestly, no way do I want to spend four days trying to get a damned water pump off... Show me this tool Cody!
                          • bmwman91
                            • Oct 2004
                            • 3128
                            You could try soaking the front of the water pump with PB Blaster and letting it sit for a day or two before disassembling everything.
                            Generally, for yanking on the pump I find it best to remove the kidney grill and radiator so that I can get a straight shot at it. It would probably be relatively cheap and easy to find a way to thread some M6 bolts into the pump flange and attach a slide hammer somehow too. Luckily none of my pumps were ever that badly frozen and prying with a very large screwdriver between the back of the flange and the timing cover (with a small block of wood between the driver & cover) always worked.
                            • cody_eppler
                              • May 2013
                              • 38
                              If you see the puller few comments up its sorta like that id say. threehz. Dont be nervous at all. Ive never done it and i just pulled it all apart its super easy. once you get in there you will understand how easy it is. Just remember there is always r3v for all the questions you could ever need to know. Also if you wanna see that tool send my a pm.
