Help, need Intake stud thats NLA.
  • thebutcher37
    • 2877
    Someone help!
    The Stud Bolt I need (#2 in the drawing diagram) (M7X85 - P/N:07129908126) that is causing my intake leak is NLA. How can I get one besides finding one off of a junkyard car?
    Photo of location where this stud bolt is found.
    Photo of stud bolt, but needs to be longer (M7X85)
    Anyone have a m42 engine for parts and willing to sell me the stud bolt and nut?
    Transaction Feedback
  • LJ851
    • 7918
    Maybe part # 6 in this diagram will work?
    http://www.realoem.com/bmw/showparts...56&hg=11&fg=15
    Lorin
    The M30 is God's engine.
    • DER E30
      • Sep 2013
      • 2344
      Order some metric all thread???
      -Christian
      • TimeMachinE30
        • Jun 2014
        • 3749
        McCaster-Carr
        ACS S3 Build / Dinan 5 E34
        • LJ851
          • 7918
          Originally posted by TimeMachinE30
          McCaster-Carr
          7mm hardware of any type is pretty uncommon, it is usually a specialized fastener. McMaster doesn't carry any 7mm fasteners.
          Lorin
          • thebutcher37
            • 2877
            Thanks, this is what I will end up getting. Glad you found it, I couldnt. :(
            McCaster-Carr
            Ah I tried this, went crazy couldn't find it.
            THIS ^ I don't recall but if they do, it was too short in length.
            • TimeMachinE30
              • Jun 2014
              • 3749
              Glad you found them!!
              • AndrewBird
                The Mad Scientist
                • 11898
                Fastenal has 7mm threaded rod FYI:
                https://www.fastenal.com/web/products/details/11505181
                • LJ851
                  • 7918
                  Class 4.6 though, the bmw studs are 10.9
                  Lorin
                  • LJ851
                    • 7918
                    Did this work out for you?
                    Lorin
                    • jrobie79
                      • Mar 2006
                      • 2525
                      I dont think that really matters for the intake manifold...it just needs to be strong enough to squeeze the gasket a little and create a seal, I'd use that without hesitation
                      1991 318i ---- 308K - retired
                      • thebutcher37
                        • 2877
                        Yes using the part in the diagram quoted above. It was direct fit and worked perfectly fine. No intake leak thus far. (I finally got to doing this a couple days ago, so fingers crossed)
                        Sounds reasonable, but I just went with an oem part for better feels. Like nice warm fuzzy feeling. It was cheap too.
                        Anyways, thanks to all who contributed.
                        I wish I had taken some photos for good measure, but didn't. :(
