m42 gearbox
  • viliusE30
    • Jan 2015
    • 2
    m42 gearbox
    Hi, im about to replace my m10 engine with m42(from e36), got kinda evrything i need, exept prop shaft. so i got question- e30 m42 gb is same as e36 m42 gb ? or difrent length? Thanks for anwsers :)
  • TobyB
    • 5263
    Very different in this country. We got a 4-speed + overdrive box in the E30,
    and the same 5- speed (no overdrive) as the six in the E36.
    And different differential ratios to compensate. Honestly, I never measured
    to see if they're different lengths!
    I don't know if that's true in Europe, but it's worth making sure.
    hth
    t
    • viliusE30
      • Jan 2015
      • 2
      guess tomorrow i will check it a hard way :) here in lithuania factory e30 318is is realy rare,
      so get e30 m42 prop is like finding unicorn. so after some reserch i find out that m10 and e30 m42 props is almost same lenght, so thats why i want to know if e30 and e36 m42 boxes are same size :)
      • benz-tech
        • Jan 2011
        • 357
        The g240 in the M42 E30 is about 2" shorter than the G250 in the E36. I haven't done exact measurements but I have confirmed I will need to shorten the shift linkages and drive shaft when I swap my 250 in. I don't know what transmissions you have in your country.
        You say "Where are your other two cylinders?"
        I say "Where's your other camshaft?"
        Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
