Unplugged FPR, runs the same.
  • lolcantturn
    • 4588
    M42 car. Lil rough idle. Unplugged the vacuum line to the fuel pressure regulator, car still runs the same (plugged the line with my finger to not cause a rough idle from a vacuum leak). Probably a faulty FPR, right?
    Originally posted by TSI
    OEM+
  • vpilarrt
    • Jun 2006
    • 2096
    Maybe not. IIRC FPR only changes the pressure when you rev the engine.
    • lolcantturn
      • 4588
      Fair enough. I'll rev the engine with it unplugged and see what happens.
      OEM+
      • TobyB
        • 5298
        Not as I understand it. FPR vacuum line keeps the fuel pressure linked to intake manifold pressure at
        all times.
        The only way to really tell is put a gauge on it, then unhook it and try pulling a
        vacuum on it. Fuel pressure should be about 45 lbs - whatever vacuum you're pulling
        on the port....
        t
