Open Breather
  • rlotti
    • Feb 2014
    • 12
    Open Breather
    When I got my e30 it was beat up and had a aftermarket intake and the breather was open. I'm trying to troubleshoot it myself but am having difficulties.
    This is what I have tried so far:
    I tried to go to the junk yard and get an airbox for an m42 so I could put it in. I think I got the wrong one. Can people post pictures of there m42 airbox's and where I should connect my breather hose to.
    I covered the breather hole with my finger today and oil started spewing from this blue hose, any ideas?
    Here are pictures
  • Gerta
    • Sep 2009
    • 2119
    M42club.com will be your friend! http://www.m42club.com/forum/index.php?topic=2742.315
    You are also missing the correct intake boot and AFM. Why anyone would do that to an M42 engine is beyond me.
    Parts Collector and Former Houndstooth interior junkie.
    • Gerta
      • Sep 2009
      • 2119
      You need BMW Part # 13 71 1 734 385
      Order your parts from Blunttech.com or steve@blunttech.com.
      He will help you get what you need.
      • Cosmic Serpent
        • Mar 2012
        • 154
        As stated you need the OEM intake boot, however you should be able to do with out. i have in the past bypassed the intake boot port via connecting the breather to the port under the throttle (not the small fpr hose) using a T fitting.
        That being said the vacuum lines should be a closed system after the AFM, so the blue line needs be connected to something. Where does it start?
        My advice would be to disconnect all vacuum hoses and start fresh using the mess under the intake guide lines. I say this b/c the blue line that you point out should not be on that side of the car.
        BTW was this an attempt at a turbo set up? (it appears to have a number of extra hoses/ fuel pressure gauge)
        Feel free to PM me if i need to be more specific.
        • Gerta
          • Sep 2009
          • 2119
          OP - Cosmic Serpent is on to something here. What is the goal of your build/repair? If you are going to return it to stock, then it looks like you have some work to do.
          • Gerta
            • Sep 2009
            • 2119
            • econti
              • May 2014
              • 1152
              alternatively run it into a catch can
              • SlickAlpinweiss
                • May 2015
                • 204
                Apologies for thread jack.
                Could I delete the vacuum line from the valve cover and in place add a breather filter?
                I've already routed the vac lines from the mess under the intake, currently I also have an open pcv. Will adding a filter cause negative effects? Is it better to run it as a vac line?
                Thank you.
                • Gerta
                  • Sep 2009
                  • 2119
                  Personally I think you should run it as a vac line to avoid vac issues. I know folks run a catch can but it still terminates back on the boot.
                  • SlickAlpinweiss
                    • May 2015
                    • 204
                    Thanks, I think I will do that. It does look like I'd be getting a little oil coming back through so I will look into a catch can. Any idea what or where I can get a T-connector (oem part #) to run a line both through the boot and throttle body?
                    I also wanted to ask about those silicone hoses from hiperformancestore, If I were to buy the kit, would it have long enough 19/32 line for this modification? or would I be better off piecing together a kit of lines? What size did you use to replace and attach from the icv elbow?
                    Mahalo, I appreciate your help.
                    • Gerta
                      • Sep 2009
                      • 2119
                      My kit had a long enough line. The kit has instructions which I do not remember off the top of my head. I have mine running from the valve cover to the boot. I'll take a pic tomorrow and post it up.
                      You could try a hardware store, but if you did the mess under the intake (and you should do that) then the T connector is unnecessary. Read the entire thread on M42club.com or Simon's Mess Under the Intake on R3V. You will have the collective knowledge of many at that point.
                      • SlickAlpinweiss
                        • May 2015
                        • 204
                        hmm, I think I did read a post where some came across the same issue.
                        I have two holes in my intake boot, and 2 holes from the engine that need lines, and one from the tb.
                        I think what I will be doing is: run line from icv goes to intake boot. Run a line from pcv to throttle body. plug the other hole in the intake boot.
                        Does that sound like it would work out well?
                        Currently my car is sitting with no line in pcv, that other hole in the boot is elbowed into the tb. It is idling very smoothly though.
                        • econti
                          • May 2014
                          • 1152
                          Idle control valve must be connected to throttle body as far as I understand
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            op are you boosted? By covering the VC breather hole you are pressurizing the crank case thus causing oil to spew out the turbo oil drain
                            Turbo M42 Build Thread :Here
                            Ig:ryno_pzk
                            I like the tuna here.
                            Originally posted by lambo
                            • gearheadE30
                              • Jun 2007
                              • 3734
                              I run an open breather on my turbo setup. The actual PCV separator is in the valve cover, so there is very little oil carryover. Mine just vents down by the transmission tunnel, under the flywheel housing. I ran a catch can for awhile, but in the winter it would ice up and pressurize the crankcase, which is no good.
                              PM me if you need any of those M42 parts - I have the rubber boot, AFM, airbox, all that stuff, that I really don't need anymore.
                              Project M42 Turbo
