Losing lots of coolant but no smoke
  • Beemerdan
    • Nov 2012
    • 192
    My 1991 M42 is losing pretty muck all of the coolant in the expansion tank within 500 miles. No smoke, on startup or while driving. The profile gasket was replaced around 20,000 miles ago.
    Any ideas what it may be or where to look?
    Thanks
  • audiquattrot
    • May 2008
    • 3836
    under your dash wet? in the footwells?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • Beemerdan
      • Nov 2012
      • 192
      Nope, totally dry.
      Sent from my VS980 4G using Tapatalk
        If you can't find any leaks with a pressure test, there is the possibility of head gasket leak that is pumping air into the cooling system. Eventually the pressure will get high enough to lift the cap, which will dump coolant overboard. That may only happen while driving and leave no trace as to what happened.
        The definitive test for this is to pressurize each cylinder with 180psi air for several minutes while monitoring cooling system pressure with a 0-5psi gauge. If the test is negative on a cold engine it must be repeated with the engine hot.
        A DIY test is to remove the cap to release any pressure once the engine has completely cooled down when you park the car for the night. The hoses will be soft at that point. Then drive the car and allow,the engine to completely cool down. If the hoses are firm/hard then, air is being pumped into the cooling system.
        • Gerta
          • Sep 2009
          • 2119
          Thanks
          Dan, I'd pressure test the cooling system first. I had a similar issue where a hose had a pinhole leak that only leaked when fully pressurized. I think you can rent fairly inexpensively a pressure tester from your local Autozone / O'Reilly's etc ...
          Just a thought.
          Parts Collector and Former Houndstooth interior junkie.
          • TobyB
            • 5286
            I once had a water pump that failed that way too, now that I think about it...
            t
