E30 m42 swap into a e30 325i
  • euro760
    • May 2012
    • 135
    I got a 91 325is chassis auto
    Im converting it to 5speed
    My buddy has a complete m42 out of his 318 that was in a accident
    Wondering what i would need
    Assuming i need
    Driveshaft
    Engine/trans
    Shift linkage
    Mounts
    Engine harness
    Ecu
    Anything else
    I know its not as much power as a m20b25
    But getting swap for pretty much free
    Thanks in advance please only helpful comments
  • roguetoaster
    Biggus Tippus
    • 7830
    I think you have it sorted out, however you shouldn't need the driveshaft, but I would pick the best of the two you have available.
    You might want the fuel system too, but in theory your 91 should have all the right stuff to make the swap work.
    • euro760
      • May 2012
      • 135
      Coo thanks alot bro
      I would be picking up his full swap with injectors and rail
      Another thing i was worried about was the m42engine harness fitting the 325i underdash harness
      • roguetoaster
        Biggus Tippus
        • 7830
        Originally posted by euro760
        Coo thanks alot bro
        Should have been more clear, meant just the fuel pump/tank in that case.
        Wish I could comment accurately on the harness in the cabin.
        • TobyB
          • 5243
          Tach, maybe, or at least the coding plug.
          In theory the cabin wiring should work. In theory...
          You may have to jumper the neutral/park switch from the trans.
          It stinks there's not an ETM for the 91 318, or you'd know for sure.
          But looking at the E36 318 engine and body diagrams might help...
          t
          • bmwman91
            • Oct 2004
            • 3134
            Yeah you will need the coding plug for the cluster and OBC for them to work properly.
            The M42 cars also had the smaller gas tank (56L I think) and the M20 cars had a larger one (63L I think). You can use the larger one since it has the dual level sensors and the higher capacity fuel gauge in the cluster already.
            Transaction Feedback: LINK
            • euro760
              • May 2012
              • 135
              Thanks alot guys!
              • DesktopDave
                • 134
                I think they're pretty close. C101 should line up correctly but I'm not 100% sure. I use a '92 'vert ETM for the '91 M42 wiring. It's been correct so far. The M42 doesn't have a sender for the oil level.
                Don't forget to short out the old auto trans harness, car won't start otherwise.
                Save the manuals!
                '91 318i
                '86 635CSi
                • irish44j
                  • 2763
                  if your car isn't an ABS car (e.g. an early 325), make sure to dummy off the ABS wire in the C101 from the M42 engine side harness. If you don't, you'll be putting power to ground and will melt a lot of wires.
                  If your car has ABS already, should be plug and play IIRC.
                  Stage rally/rallycross e30 build/competition journal
                  Track/street e21 build
                  visit Condor Speed Shop
                  visit Motorsport Hardware
                  [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
