M42 Rod Knock
  • CFeld
    • Jun 2016
    • 102
    M42 Rod Knock
    I finally sprung for a timing tool for the m42. I got the engine timed and finally it would idle on its own. But the worst that could have happened came and screwed me. I have a rod knock, no hole in the block, but I don't have the money to rebuild the engine. I can get a full m20 with all the accessories for $250. Anyone selling a getrag 260 trans and driveshaft? Thanks
  • Dj Buttchug
    • Jun 2010
    • 7688
    what makes you think you have a rod knock?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • CFeld
      • Jun 2016
      • 102
      It's a long story but essentially when I pulled the engine one of the connecting rod bearing caps was loose. I torqued it up but I don't think it clamped together correctly.i had a bad feeling
      • TobyB
        • 5298
        Bummer. It would have been cheap to throw new shells in there when you found it was loose....
        t
        • CFeld
          • Jun 2016
          • 102
          I'm working on it. I will be posting the time-lapse of the engine being pulled again tomorrow.
