E36 M42 Motor mounts on E30?
  • jaredmac11
    • Sep 2007
    • 253
    Im thinking these mounts are identical, but has anyone used the e36 m42 motor mounts on the E30? Do they go right in? I'll be creating custom perches for my e21 so I know at least I'll make it work for the subframe.
  • roguetoaster
    Biggus Tippus
    • 7830
    Negative, check out a thread I did in this section on cutting a mount open as a comparison.
    • jaredmac11
      • Sep 2007
      • 253
      Ah-ha. I see it is the locating bump that throws a wrench in it.
      • jaredmac11
        • Sep 2007
        • 253
        FCP Euro has parts on clearance. Found OEM mounts for $60. E36 we're only $45 but $60 isn't bad for oem!
        • roguetoaster
          Biggus Tippus
          • 7830
          $60 is a good deal, lower than it has been for years.
          • benz-tech
            • Jan 2011
            • 382
            I ground the nub off. They running smooth for two years now. Came with my M44.
            You say "Where are your other two cylinders?"
            I say "Where's your other camshaft?"
            Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
            • dlmrun2002
              • Apr 2007
              • 808
              You can cut off part of the mount to make it fit. I had a poly mount disintegrate on me on a BMW vintage show and had a shop make a go out of it using a e36 mount since that is all he had..
              dlm
