Hello im new to the forum, but on my second e30 vert with the m42. The PO told me the motor had been rebuilt from the bottom up. Until recently i felt like the car was flawless with of course all its little flaws or "Personality Quirks" now 2 weeks after owning it i'm noticing more and more. The car doesn't overheat but it runs around the 1/2 to 3/4 mark depending if i'm sitting or driving. I also saw signs of water in the oil via the dipstick, however the milky oil is higher on the dipstick about 1-2 in from where the oil level is. Which is right under the max. The car has also been blowing a pretty light smoke that doesn't really look like a head gasket leak, and just smells like a normal exhaust. The car also blows hot air. I know these cars need attention and i don't want to end up with another cracked head. I plan on doing the water pump, thermostat, and a coolant flush soon. Just looking for advice or any help on the issue. Maybe the thermostat gauge is off?
Between work and life i don't get a whole lot of time to investigate. I am driving this car about 30 miles to and from work though and just want to be able to trust it. I am open to any and all suggestions. Will post pictures soon. Thanks in advance and hello to all on R3V.
