Leak Down #'s Opinions Wanted
  • e30sh
    • Apr 2015
    • 618
    91 M42 302K miles
    Compression test hot 1 to 4.
    175 / 170 / 170 /175 psi
    Leak Down Cold @ 100 psi
    18% / 22% / 23% / 19%
    2 and 3 have no bubbles in the coolant but the coolant level slowly rises and overflows out of the expansion tank when pressurized. 1 and 4 are normal.
    While running with the valve cover vented to atmosphere and the throttle nipple capped, I'm getting some steam / blowby out of the valve cover.
    Car runs well, doesn't overheat and the plugs look normal. It looses a few inches of coolant out of the expansion tank every 500 miles.
    No oil in coolant or coolant in oil.
    Crack / Profile gasket?? Car wasn't overheated. Do they normally crack in two cylinders? I assume the head gasket is OK based on above.
  • e30s50dan
    • Nov 2008
    • 2076
    I'm in the middle of a rebuilt,and had the same numbers.on the engine stand while doing the leak down test I had bubbles on both intake and exhaust valves ,while spraying carb cleaner.
    Result...carbon build up!!
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • e30sh
      • Apr 2015
      • 618
      Any theories on how the cooling system is getting pressurized only on #2 and 3? The profile gasket would show on all 4 I assume.
      • jaredmac11
        • Sep 2007
        • 253
        It sounds like youre thinking it has a crack? Have you done the test to see if there's actually exhaust in the radiator?
        https://www.amazon.com/Block-Tester-...ad+gasket+test
        This is very comprehensive as well:
        But are those numbers still within spec? 22-23% doesnt seem bad at all.
        Have you ruled out coolant leaks due to the plastic pipe, bad hoses, etc? Have you tried the radiator leak tests?
        • roguetoaster
          Biggus Tippus
          • 7830
          They normally crack between a valve seat and a coolant passage in cyls 2/3.
          So, when the coolant overflows the level is way below cold when the car cools? Have you double checked that it's bled really well?
          • e30sh
            • Apr 2015
            • 618
            Have not done a chemical test to the oil or coolant but they pass the visual test.
            The coolant level will be at the line in the expansion tank. Pressurize the cylinder and in ~30 sec it will overflow with the cap off. Once pressure is removed from the cylinder, the coolant level does not go back down. Crank it up and drive it a bit and the level returns to normal.
            It's been slowly loosing coolant for over a year. I just top it off and go. It doesn't get driven that much, ~4k miles / year.
            Do they normally crack in two cylinders? I assume if #2 is cracked, # 3 will read normal or do the cooling passages tie together between 2 and 3 but not 2 and 1 etc.
            The no bubbles thing is confusing. I had an M44 years ago with a warped head. It blew bubbles in the expansion tank with #2 pressurized.
            • jaredmac11
              • Sep 2007
              • 253
              FWIW, I pulled a head with a crack at this exact location.
              • e30sh
                • Apr 2015
                • 618
                In both cylinders or just 1
                • e30davie
                  • Apr 2016
                  • 1788
                  Unfortunately if you are getting any sort of issue between the cylinder and the cooling system, its time to pull the head off and investigate.
                  Cracks in heads is not the end of the world. But will require some rectification in the machine shop.
                  • jaredmac11
                    • Sep 2007
                    • 253
                    The crack was not between the two cylinders but was at the exhaust valve port at the surface of cylinder 3.
                    It was not between the 2 & 3. Just because cylinder 2 & 3 are low pressure, I wouldnt automatically state that the crack is between those two cylinders necessarily. Im not a mechanic but that test isn't end-all. Youd have to pull the head to verify.
                    The good news is, that would be the time to do a full refresh if you havent yet.
                    • TobyB
                      • 5250
                      Time to pull the head.
                      t
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        Usually only one cylinder area on the head exhibits a crack.
                        • TobyB
                          • 5250
                          ...and it's not unusual for the head gasket to lift in the middle, so your bubbles make me
                          agree with everyone above, and guess that you'll find a failed head gasket
                          (and possibly warped, but not cracked, head)
                          t
                          prognosticating
                          • e30sh
                            • Apr 2015
                            • 618
                            t
                            prognosticating
                            I had a M44 with a blown head gasket between 2 and 3....it blew bubbles in the rad while doing a leakdown. This M42 does not...just raises the cooling system level.
                            Since it was on 2 cylinders, I was hoping it was the profile gasket somehow.
                            Air gets past the rings into the block back up to the profile gasket. Cylinders 1 and 4 don't leak as much past the rings to allow air back to the profile gasket. That's why I was curious if they normally crack in 1 or 2 cylinders.
