Need advice from experience for an M42 rebuild
  • JonsE30
    • Jun 2018
    • 160
    #196
    how do i test if the clutch engaging/disengaging without the pedal? which line fitting up stream to do you mean? do you mean this part?
    • roguetoaster
      Biggus Tippus
      • 7813
      #197
      Put the car where it would roll or have a helper push against it with the car in gear and try both clutch engaged & disengaged.
      You can start with cracking the line there and then move to the junction of 19/10. You may end up having to both crack the line at the location in the pic and bleed the slave by hand to encourage fluid movement.
      • JonsE30
        • Jun 2018
        • 160
        #198
        Oh i see. So the test is if the clutch engages when pedal is pressed, it should be able roll like if its in neutral, but if it doesn’t roll then the transmission stays in gear which mean the clutch is not engaging when i press the pedal?
        • roguetoaster
          Biggus Tippus
          • 7813
          #199
          Just as if you were parked facing up a hill with the car in a forward gear and no hand brake engaged. Press the clutch and you'd roll back.
          A worse test would be to start the car wherever, press the clutch pedal and select a gear. If you hear a grind the clutch is not working.
          • JonsE30
            • Jun 2018
            • 160
            #200
            gotcha, i will test for fluid first since the slave cylinder is now separate from the transmission. if there is no fluid where is it ? haha. does that mean there is a block or obstruction within the lines or an issue with the master cylinder since from the reservoir it has to go through the master cylinder first before pushing fluid to the lines that go to the slave?
            • roguetoaster
              Biggus Tippus
              • 7813
              #201
              You won't know until you open the line unions. I'd guess that you just have a bubble/air lock situation somewhere that can't quite pass. Worst case you have a failed slave or master, but you'll know soon.
              • JonsE30
                • Jun 2018
                • 160
                #202
                update: went to put back the slave cylinder back in the transmission but decided to try again. it look like the reservoir was not at the max line. i topped it off and tried hand bleeding it and i got fluid!. i bolted the slave cylinder back in and then got in the car and got pedal back pressure!. i was able to go in an out of the garage! hahaha. but i left a trail of brake fluid so i think i didn't tighten the bleeder enough. i am so relieved! i love this forum! i could not have done anything without you all!
                • JonsE30
                  • Jun 2018
                  • 160
                  #203
                  ive noticed when i started the car this morning. the car was blowing white smoke, but i have good compression and my coolant system isnt in yet so it's not coolant, it's probably oil. if my headgasket blew wouldn't i get lower compression? i've read somewhere and i think it was commented here that the plugs under the intake would be switched and make it's run rich. could this be it. it's not like as bold or strong like when it blew before the rebuild.
                  or could it be the bad gas sitting in the tank? bad plugs? all the above? haha.
                  • roguetoaster
                    Biggus Tippus
                    • 7813
                    #204
                    Could be any of the above, or water vapor from the exhaust system, probably not bad plugs. Plugs under the intake should have aged wiring that make them "belong" to only one sensor, either way, there's one one pin connector and one two pin connector IIRC which go to corresponding sensors.
                    *added something that was unclear before
                    • bmwman91
                      • Oct 2004
                      • 3128
                      #205
                      The gray plug (with 2 populated terminals) goes to the coolant temp sensor for the ECU (also with 2 terminals). It is part of the same branch as the oil pressure switch plug (1 populated terminal). Then there is the plug for the coolant temperature sender for the cluster (1 populated terminal) and its plug is separate from the aforementioned two. I did once swap the two 1-pin plugs (which was scary since it caused the oil light to be on and the temp needle to fly into the red), but the one that matters in your case is the 2-pin one since the ECU reads that to define warm-up enrichments.
                      And yeah, if there is no coolant in the car then at least you know it isn't burning any! What is the longest that you ran the engine for without the cooling system?
                      If the HG was blown, I would expect at least 2 cylinders to read a bit low. When I had it go out between cylinders 2 & 3, I got ZERO compression on them.There were hairline cracks between 1-2 and 3-4 as well, and I was getting like 60PSI (cold engine). If you are going to fail, I guess you have to go big lol.
                      What are the ambient temperatures when you are seeing the "smoke"? I'd guess that it is just water condensation from the cold exhaust and rich running, which normally oges away once the engine warms up (which you have not had the chance to do yet).
                      Transaction Feedback: LINK
                      • JonsE30
                        • Jun 2018
                        • 160
                        #206
                        roguetoaster probably the longest i kept the engine running is probably 10 minutes so i can get the oil hot so i can find leaks. once i saw the temp reach almost half i shut it off.
                        bmwman91 the ambient temp was maybe 60-65, it was earlier this morning like 8AM when i strarted it up this morning.
                        i was researching online images to see if i get the sensors mixed up, the one closest to the front of the engine is a light blue sensor, which has a grey connector plugged to it. the orange one is in the middle of the head which has a black connector to it. the brown sensor plugged to the oil filter housing that has a black connector to it that looks like it was Y split from the gray connector going to the the blue sensor.
                        i dont have an oil warning light when the engine is idling/running. i have a quarter tank of gas left in the tank and it's been sitting there for 2 years during this whole rebuild if that means anything. does it run "less-rich" once i started driving it more? or is it something i can adjust right now? i don't have a check engine light.
                        • roguetoaster
                          Biggus Tippus
                          • 7813
                          #207
                          Likely water in the fuel from ethanol being hydroscopic. Fuel these days seems to be good for about 6 months in a full tank in an older car, although it will often still combust as gasoline is hydrophobic. You seemingly get much less storage time if the tank has more air space.
                          • bmwman91
                            • Oct 2004
                            • 3128
                            #208
                            Hmm, well 10 minutes with no coolant is a bit of a long time. The temp sender for the cluster isn't necessarily reading accurately since it is immersed in air rather than flowing coolant, hot spots can form since heat i sbasically only conducting in the metal at that point, etc. Anyway, your compression test likely ruled out a warped head, so it may well be bad gas or just normal condensation from combustion. Honestly, the main thing at this point is to get that coolant system back on there and give it a drive.
                            Look at it this way...worst case you have to pull the head and get it surfaced again to deal with warping, or it cracked and you need to find a good used one to get surfaced. You'd be in for $250-500 in parts and machine shop labor at that point which sucks, but isn't the end of the world.
                            • JonsE30
                              • Jun 2018
                              • 160
                              #209
                              I’ll get the cooling system in ASAP. Damn I hope i didn't warp or crack the head. This engine is definitely schooling me.
                              • JonsE30
                                • Jun 2018
                                • 160
                                #210
                                I got leaking from the water pipe connected to the block. Is this the right o-ring? And is it installed correctly? Sent from my iPhone using Tapatalk
