Engine Seized?
  • herbie
    • Jan 2011
    • 206
    Engine Seized?
    Hi Guys,
    Need help here. I know this is M42 forum, but my question is about an M44 which is a similar engine. i could ask at 318ti.org but I am biased to R3v members.
    So, my brother gave me a 1999 318ti that doesn't run. He said it died on the freeway and the engine has no oil. no noise, no clunking, just shut off.
    It is dead in my garage right now. I put oil and some in through the plug hole. If I try to turn the crank by hand, I can't.
    Engine toast? or is this salvageable?
    Thanks,
  • fresh_TD
    • Aug 2013
    • 2457
    If you can't turn by hand, it's toast.
    Sent from my Pixel 3 using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • herbie
      • Jan 2011
      • 206
      fresh TD, thanks for the confirmation.
      Now, just a matter of what to put in there.
      • fresh_TD
        • Aug 2013
        • 2457
        Get another M44., They're good engines and cheap to buy.
        • herbie
          • Jan 2011
          • 206
          Might just do that. was hoping it was not seized, oh well. He wouldn't be giving me the car if it wasn't.
          • jrobie79
            • Mar 2006
            • 2526
            It's taken me in the past a decent amount of effort to get it to turn over by hand, throw some penetrating oil in the holes and let it sit for a while, then try. Use a breaker bar to get a decent amount of leverage behind it
            1991 318i ---- 308K - retired
            • roguetoaster
              Biggus Tippus
              • 7830
              Do the above, but also remove the VC to look for top end damage or a chain that's not tensioned in case it's valve interference.
              Also rotate the engine the opposite way if you haven't already.
              As to a swap, and S52 in a ti is a lot of fun, ask me how I know. But an M54 would also be a good option.
              • bmwman91
                • Oct 2004
                • 3134
                Be careful not to rotate the engine too far in the CCW direction. The timing chain can bind and get stuck or jump a tooth down at the crank sprocket. Just go enough if that's what it takes to break it loose.
                I also second pulling the valve cover and poking around for signs of distress.
                Transaction Feedback: LINK
                • Sonny
                  • Feb 2019
                  • 100
                  Engine Seized?
                  Not recommended but when I had a seized motor I put tranny fluid instead of oil and let some penetrating oil soak the spark plug holes. Then I Tried turning motor by breaker bar. Took me 3 days of trying to turn it with a older rusted car but managed to free it and then immediately change oil.
                  Do a engine swap the motors are cheap
