M42 won't start
  • kencopperwheat
    King of Kegstands
    • 14396
    #76
    Originally posted by E30 Groupie
    Only when cranking? I can hear my m20 pump when i turn the key to on... ?
    I really don't remember... and mine is several miles away so I can't check :(.
    Originally posted by Gruelius
    • Funkmasta
      • May 2004
      • 7185
      #77
      4 most common M42 no-starts in my experience
      Ecu
      Crank position sensor
      fuel pump
      intake leak
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • Jordan
        • 12913
        #78
        I don't recall on M20 cars, but on M42 cars the fuel pump does only run in crank or run.
        https://mtechniqueabs.com/
        • Funkmasta
          • May 2004
          • 7185
          #79
          Curt, try to crank it and the pull a plug... see if it's wet. OR have someone crank it and get your nose down by the tail pipe...
          That Guy.
          • Van Westervelt
            • 9365
            #80
            Crank
            • kencopperwheat
              King of Kegstands
              • 14396
              #81
              UPDATE:
              Pulled the head tonight. Everything looked fine. Is there place I should look for warpage? Will it be obvious? The head looked perfectly straight. Bit of build-up on the cylinders, but that's 280k for ya.
              Head is going to be pressure tested before it's reinstalled.
              • Joe318is
                • Sep 2005
                • 6451
                #82
                So? what have you found?
                Originally posted by vlad
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  #83
                  Head still hasn't been pressure tested. We need to remove the cams first. The plan is to remove them today or tomorrow and then have it tested. If it checks out alright, we'll slap the cams back in and remount them head on Wednesday. If it compression tests OK after that we're going to remount everything and try and fire it up. A long work schedule and not having the car near me has made this a slow process.
                  • M42Technik
                    • 9781
                    #84
                    M50 swap. ;)
                    Reminiscing...
                    • 318ls
                      • Oct 2007
                      • 2
                      #85
                      My M42 didn't start as well 3 weeks ago. After going through all sensors, I did find out the CPS have gone hell. Do a simple check with your DMM, it should read about 560 Ohm or so. Mine actually read over 1500kOhm...
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        #86
                        Both crank and cam sensors read well within spec. I also replaced them with known working ones.
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          #87
                          I should get the diagnosis on the pressure test of the head this afternoon.
                          • Funkmasta
                            • May 2004
                            • 7185
                            #88
                            Aluminum head rebuilders says: exhaust valves not seating, due to carbon buildup. Fairly common with the M42s they said. The flash carbon buildup was probably due to a minor overheat...
                            hmmm
                            That Guy.
                            • Simon S
                              • Oct 2004
                              • 3758
                              #89
                              update ?
                              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                              • kencopperwheat
                                King of Kegstands
                                • 14396
                                #90
                                Originally posted by Simon S
                                update ?
                                Ran like a champ once the head was popped back on.
                                Now to fix the leak from the thermostat housing :/
