Cam Gear Question
  • dvmotorsports
    • Apr 2008
    • 658
    Cam Gear Question
    Okay, there are two nipples on the cam gears in the M42. One on each gear. There is a what i believe to be a hall effect sensor on the front cover that reads the exhaust cam gear. The question is this...
    When reassembling the motor with cyl #1 at TDC where do the nipples need to point? i have the Exh at 2 o'clock and Int at 10 o'clock.
    Originally posted by jrhaile
    For the record I have never fucked a goat.
  • dvmotorsports
    • Apr 2008
    • 658
    bump
    • dvmotorsports
      • Apr 2008
      • 658
      bump
      • txleadfoot
        • Apr 2006
        • 208
        there is a square block at the backside of the camshaft. The two dots should be pointing upwards at TDC.
        • e30serg
          • Dec 2006
          • 562
          pic?
          • Cobra Jet
            • Apr 2008
            • 278
            go to this thread - there's tons of "open M42" pics showing the alignment of the cams & cam gears... look through each page as multiple M42 owners have posted a slew of pics...
            • E30nate
              • Oct 2007
              • 1050
              on the gears there is also an arrow on the front. those need to point directly up with the engine at tdc
              • dvmotorsports
                • Apr 2008
                • 658
                ^ thanks cobra and nate. i forgot about the arrows. that solved the problem.
                • peerless
                  • 285
