Loud clunking from the rear... Axle tramp?
  • drevilkep
    • 8
    I was sure it was the diff bushing, but that didn't totally solve the problem. Here's the deal: when I'm taking off from a start (I do this a lot in DC traffic), sometimes I'll get a shaking in the rear that will build up until things start clunking around. I thought it was the diff bushing allowing the diff to move, but replacing that only partially solved the problem. I'm also getting a clunk whenever I lift or apply the throttle, most noticeable in the 30-50mph range. Also, there is a distinct side to side shaking feeling I get between 20-30mph when crawling along in traffic. Is this a center support bearing? Seized u-joints? Or something else?
  • gearheadE30
    • Jun 2007
    • 3734
    Start with the center support bearing. It may be the CV or u-joints, but those also tend to rattle when they go bad, and don't have much effect under steady-state acceleration.
    Project M42 Turbo
    • Danny
      • 14216
      Check your exhaust hangers.
      • charlesmarseille
        • 2
        if you fixed it a bit with a new bushing, try retorquing the upper bolts that hold the diff on the chassis. they usually get loose and allow the axle to pivot around the hubs center of rotation, do to the centrifugal force. and give some update.
        • kev.skyline
          • Dec 2008
          • 19
          rear subframe bushigs deffinatly
          • kencopperwheat
            King of Kegstands
            • 14396
            Rear SF bushings.
            Originally posted by Gruelius
            • EN318isPDX
              • Oct 2007
              • 4373
              CSB or CAB
              • Defunkt25
                • 14
                I had the same problem. Its most likely the exhaust. My exhaust tip had actually cracked.
                • kencopperwheat
                  King of Kegstands
                  • 14396
                  could def be csb and/or bad ujoints
                  • Brew
                    • 3060
                    Could also be a bad CV joint. Check for play between the hubs and axle shafts.
                    '91 318is
                    • wolfgangstbd
                      • 960
                      mine does this too. im pretty sure its the csb ill fix it when i get some money. Do yours and tell me if it helped! haha
                      • twright
                        • 707
                        Before you take anything apart, make sure that the u-joint nuts are tight and the differential-to-subframe bolts are tight.
                        If any of these are loose, you will get clunking noises.
                        Don't ask me how I know.
                        • wolfgangstbd
                          • 960
                          how do you know ahah
                          • Doughnut
                            • Oct 2007
                            • 869
                            I have same problem in my 323i, it's the subframe bushes slopping around.
                            Good place to check on top of everything else anyway.
                            ///Monstrosity. (OO≡≡[][]≡≡OO)
                            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
