Cold start, Unable to drive.
  • vfstyles
    • Apr 2008
    • 58
    check the TPS and fuel pump.
    • fiftytakedowns
      • 2460
      the fuel pressure was perfectly fine, how do I check the TPS?
      [/url]
      Team USA Wrestling 67KG
      • vfstyles
        • Apr 2008
        • 58
        start the car and use a multimeter to read sensor output.
        backprobe the sensor while running and check voltage at idle. open the throttle by hand and record the change in voltage. your readings should be in the 0-5v range.
        • fiftytakedowns
          • 2460
          ICV is not buzzing..... when It was unplugged The idle smoothed, when cold, though it became a bit more lumpy.
          Also Squeezed the hose going into the ICV, and it did not change anything.
          also read code 1244 after inspecting a bunch,but previously it was 1215, but I checked the AFM's were both good.
          [/url]
            • 34839
            if your ICV does not buzz with the ignition turned on then it's dead.
            • fiftytakedowns
              • 2460
              So far I have replaced the Coils, Replaced the ICV, replaced the AFM, checked for vacuum leaks. I CAN NOT FIGURE THIS OUT!!
              motor still pulls a coil 1 code
              [/url]
              • fiftytakedowns
                • 2460
                yet It still bogs down at 2k rpm, and often *jumps, or misfires* around 3.5k.
                [/url]
                • slo325i
                  • 417
                  My nissan used to do this when it had the wrong chip in the ecu.
                  '89 325i - Totaled... good bye my love...
                  '87 327i budget stroker - SOLD!!!
                  '92 240sx - ca18det powered drift toy - SOLD!!!
                  '89 325i - coupe - NEW daily
                  '96 Audi A6 Quattro- Grocery getter/baby hauler
                  '99 Busa - weekend wheelie monster
                  • fiftytakedowns
                    • 2460
                    Wierd, I had a stock chip, but now I have a Mark D
                    [/url]
                    • BraveUlysses
                      • Jun 2007
                      • 3781
                      How old are your wires?
                      • fiftytakedowns
                        • 2460
                        New coil on plugs installed
                        [/url]
                        • BraveUlysses
                          • Jun 2007
                          • 3781
                          Oh, you only mentioned "new coils" earlier, didn't know you had gone to COP.
                          How about swapping two of the coils and see if the CEL changes?
                          • fiftytakedowns
                            • 2460
                            Thats a good Idea, BUT it says coil 1 is bad, and coil one is the bad boy that needs to be modified to fit. sO i couldnt swap if I wanted to anyway. Any chance it could be plugs? It said coil 1 was bad even befor eI swapped out t bad ones with the good new ones. hmm
                            [/url]
                            • BraveUlysses
                              • Jun 2007
                              • 3781
                              If you haven't done new plugs definitely do that asap, they're super cheap.
                              • fiftytakedowns
                                • 2460
                                replaced plugs, smoothed the idle a bit, didnt fix the problem though.
                                [/url]
