Cold start, Unable to drive.
  • fiftytakedowns
    • 2460
    #61
    Hello?
    [/url]
    Team USA Wrestling 67KG
    • X_WizarD_X
      • Jul 2005
      • 99
      #62
      Originally posted by fiftytakedowns
      Crank position Sensor 512 Ohms
      That seems low for the CPS, but don't know if that is the problem...My car wouldn't even start with the reading that low...
      The Keystone Killers: for the Commonwealth!
      Member #18 of M42Club.com
      1991 318is Diamantschwarz Black
      1992 850i Calypso Red
      • fiftytakedowns
        • 2460
        #63
        That's what I figured. maybe it is cutting off the fuel pump occasionally, because it is that low.
        [/url]
        • fiftytakedowns
          • 2460
          #64
          Im going to re-test my sensors, will report back. I dont understand how this can be happening there has got to be a bad signal somewhere.
          LEts assume I just encountered this problem, What series of tests would you conduct to try and pinpoint the problem, being fuel, or spark related?
          [/url]
          • fiftytakedowns
            • 2460
            #65
            not sure if this helps, but SOMETIMES if it starts bogging down, and I floor it, the car Violently jerks between bogging, and actual ignition, like Sputtering of working and non-working.
            [/url]
            • fiftytakedowns
              • 2460
              #66
              bumping for help.
              [/url]
              • trackjunkie21
                • Jan 2010
                • 3962
                #67
                sounds alot like the cps, did you see my thread about the problem I was having? about sludge and dirt buildup on the cps? clean it with some carb cleaner.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • fiftytakedowns
                  • 2460
                  #68
                  I did see that, My CPS is perty clean :D Unfortunately that wasn't the fix though.
                  [/url]
                  • Killacortes
                    • 1937
                    #69
                    i didnt read everything on this thread, but the same thing happened on my car changed the plugs and found one bad coil. picked up a free used coil and booom runs like a champ
                    r3v does not fuck around. First you get banned, then they shoot you
                    • tjts1
                      • May 2007
                      • 1851
                      #70
                      Just thinking out loud here. From my experience with MSQ, if you don't have enough cold start enrichment the engine will run like crap for the first couple of minutes. Now if you had a failed coolant temp sensor on the M42 so that it read HOT all the time, the engine would be running way lean on cold start. Sorry if this has already been addressed in the thread.
                      • Dj Buttchug
                        • Jun 2010
                        • 7667
                        #71
                        yo fifty have you checked the AFM?
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • fiftytakedowns
                          • 2460
                          #72
                          How did you Isolate the bad coil, I was running the car with all four coils in, but not necessarily bolted down, (so I could pull them off the spark plug. I didnt find a dead cyl (this was idling).
                          Buttchug, I swapped in junkyard AFMs, and had no luck. I think I even bought an AFM off of a member with no luck.
                          justin,
                          This morning I got a cup of boiling water, and stuck my spare CLT sensor in it, with it connected to the wiring harness. and I had no luck in causing or finding any problems. I have a new CLT and a spare one off of a running engine. I have swapped em in and out with no luck.
                          I did unplug the camshaft position sensor, and reset the computer. I was getting the same symptoms, however, the backfiring was much more rhytmic
                          pop pop pop pop pop popop (not revving higher than 1500 RPMS, but holding it.)
                          as opposed to camshaft sensor in.
                          POP boggggggggg pop POp bogggggssss down back to idle. or dies.
                          yo, Thanks everyone for your help. whoever has the winning discovery I have some spare VDO gauges I can distribute. :D
                          VDO gauge winner chooses one --> http://dl.dropbox.com/u/11819570/VDO%20Gauges.JPG
                          [/url]
                          • trackjunkie21
                            • Jan 2010
                            • 3962
                            #73
                            also, are you sure that the plugs are hooked up to the right plugs? That causes backfiring popping and a shitty driving experience.:rofl:
                            • Dj Buttchug
                              • Jun 2010
                              • 7667
                              #74
                              im straight up mind fucked. im usually good at diagnosing. this is weird
                              Ig:ryno_pzk
                              • fiftytakedowns
                                • 2460
                                #75
                                it's been 2.5 years man, it's tough.
                                [/url]
