Cold start, Unable to drive.
  • chrisbmx68
    • 358
    #91
    I have almost exactly the same problem but not quite as bad, it seems to be a misfire to me. Only happens when the car is cold for like a mile or two. It doesn't bog with no load on the engine but does when under load.
    My theory is bad grounding for the ignition coils.
    I may have missed it but when cold does your car rev freely in neutral?
    • fiftytakedowns
      • 2460
      #92
      nope not at all
      [/url]
      Team USA Wrestling 67KG
      • trackjunkie21
        • Jan 2010
        • 3962
        #93
        Originally posted by fiftytakedowns
        nope not at all
        Are you going to replacing the harness? or did you not get to the CPS yet? I would rule that out, I can see no way how that can be causing the problem.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • fiftytakedowns
          • 2460
          #94
          I havent been fucking with the car since I got the 2002 started, Im kinda over putting money into it trouble shooting to be honest. trying to sell it once the 2002 hits the road.
          [/url]
          • Burnall4
            • 145
            #95
            this problem has been solved, it has to do with a sensor for the catalytic converter, in Europe they don't have one so this once sensor is not plugged in, in the US we have cats so the sensor needs to be unplugged
            Please see my thread on M42 club
            And here is a picture to help you locate the plug.
            Please excuse my MS Paint drawing, it was quick, and I did it a long time ago.
            • Burnall4
              • 145
              #96
              • trackjunkie21
                • Jan 2010
                • 3962
                #97
                Read the thread, he has said multiple times that he has done this and this isn't the problem.
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  #98
                  yea def not the issue. this 42 has demons... :( it makes me sad
                  Turbo M42 Build Thread :Here
                  Ig:ryno_pzk
                  I like the tuna here.
                  Originally posted by lambo
                  • Burnall4
                    • 145
                    #99
                    I watched the videos, and if I still had my 318 I would plug the sensor back in and take a video.
                    That is exactly what mine did, down to the rpm range, the time frame and how it sounded...the thread over on m42, other people it didn't work for, but the vast majority it was a fix.
                    good luck to you.
                    • fiftytakedowns
                      • 2460
                      #100
                      It's just a case by case basis, I bet i might work on someone else's but I have located and unplugged it, unfortunatley not the solution.
                      [/url]
                      • sdub
                        • May 2011
                        • 220
                        #101
                        i had the exact issues you describe and it ended up being the ground on the ign coil. someone had swapped for msd ignition and some shoddy wiring.
                        • fiftytakedowns
                          • 2460
                          #102
                          Interesting, ground being bad or, what?
                          [/url]
                          • Simon S
                            • Oct 2004
                            • 3758
                            #103
                            Originally posted by Highway1
                            Do you have an afm adapter lead? I've heard that some 318's have them and some don't. maybe someone took it out thinking it wasn't necessary
                            I have to ask: what is that AFM adapter lead/extension for?
                            My car has one - and I want to remove it - especially if it has no purpose.
                            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                            • fiftytakedowns
                              • 2460
                              #104
                              I didnt ahve one initially, then I got one just in case, been running with it since.
                              [/url]
                              • Simon S
                                • Oct 2004
                                • 3758
                                #105
                                Hmmm.. I guess I'll just see what happens when I remove it then..
                                Bugs me to not know its purpose or function.
                                (sorry for thread interrupt)
