M42 Stroker which pistons to use???
  • gespinal0301
    • Jan 2011
    • 317
    I'm slowly buying parts to build a M42 stroker so far I have the m47d crank that I got from fresh_td, aftermarket 140mm rods. I also have a spare motor I bought a while back along with a late M42 timing case, arp head & main studs, and a crank girdle so I'm going to buying timing components and bearings pretty soon.
    I calculated the DCH = 212- (88/2) - 140 -.15=27.8). I've been looking at m54 pistons since they have a CH of about 28mm and there's a aftermarket site that sells forged m54 pistons for pretty cheap.
    I haven't been able to calculate the CR, but anywhere above 9:1 would be fine with me since way in the future I have an idea of turboing the motor. I have a MS3X "ready" for the car just working on a few different projects so it might be a while before I can get that in.
    Any thoughts to see if the M54 pistons would be suitable in this application?
    My Daily Driven 318is
  • digger
    • Nov 2005
    • 6198
    i'd look for a set of forged slugs if you have realistic plans for a turbo unless very low boost. to get an idea on the limits of the pistons look at stock M54 and take 4/6 ths of the torque and hp number that people run on the stock stuff
    • gespinal0301
      • Jan 2011
      • 317
      That's what I was planning on: http://www.amp44.com/index.php?route...&product_id=94
      These are the ones I was looking at, there's a guy on the forum (pazi88) that's going to be running this company's pistons and they come in at a really good price.
      I just haven't seen many strokers with m54 pistons so I was wondering if it was possible and what type of CR it would give me or should I just go custom???
