Differential specs and torque values?
  • bignslow
    • Oct 2017
    • 142
    I am looking for differential specs and torque values for E30 small case. BMW shop manual only shows procedure for replacing complete diff but nothing about swapping gear sets, setting preload or adjusting the backlash. Would someone have these specs handy? I am assuming the actual adjustment procedure is same as most other cars.
  • Vincenze
    • Apr 2019
    • 1035
    You can get procedures from BMW TIS.
    • TobyB
      • 5286
      ALso, look for the E21 BMW repair manual-
      the early (77-79) diffs are the same as every 168mm diff
      after 1983. It has the preloads, torques, etc.
      I seem to remember seeing it in multiple places on the interwebs...
      t
