325ix rear viscous differential maximum torque
  • crappyroads
    • May 2022
    • 11
    Hi all,
    I got my hands on a 3.9:1 viscous rear diff that I intend to use with an LS swap. Has anyone out there had experience putting big torque to this diff? Is it possible to weld it if it can't handle the torque?
    Thanks in advance.
  • ForcedFirebird
    • Feb 2007
    • 8300
    Swap in the gear set to a typical clutch pack RWD diff case? Welding a diff sucks for anything but drift/drag racing.
    john@m20guru.com
    Links:
    • packratbimmer
      • Dec 2009
      • 1335
      Run it and see how it does. What's the worst that will happen? - you will be running open until you find a replacement.
      • ForcedFirebird
        • Feb 2007
        • 8300
        The viscous won't hold ~300lbft of torque.
        john@m20guru.com
        Links:
        • crappyroads
          • May 2022
          • 11
          Thanks for the info! I think I'll just buy a regular mechanical diff. This unit is for sale in the classifieds if anyone is interested!
          • crappyroads
            • May 2022
            • 11
            Is this more cost effective/worthwhile than just getting a mechanical diff?
