Differential Swap Options
  • Rockonp04
    • Sep 2020
    • 75
    I converted my 1991 325i from auto to manual successfully but I have a 4.10 LSD rear end. I want a 3.73 LSD rear end but looking at all the prices for even used ones, it's kinda depressing. What's even more depressing is the cost of a refurbished 3.73 rear end. I was thinking of just buying a new 3.73 LSD gear set and having it installed in the 4.10 case. I need to know if this is an option.
  • Vincenze
    • Apr 2019
    • 1046
    If you have to ask somebody knowledgeable (as you should) to set it, it'll be expensive.
    Good 4.10 LSD differentials cost the same as 3.73 differentials.
    • digger
      • Nov 2005
      • 6216
      buy a good used gearset from eBay and swap it in (new gearset will be bulk $$$). I did this earlier this year it is not difficult at all or expensive . There are YT videos showing how to do this. you will need a press though to make your life easy but a cheap one for couple hundred will do the job
      • jbontke
        • Mar 2019
        • 449
        Check out Racing diffs vids on youtube - https://www.youtube.com/watch?v=O84d0y-vfBw
