Auto to Manual swap final hurdle.. wiring for euro car help please
  • MatBiscuits
    • Jan 2023
    • 36
    Hi all,
    I have scoured the internet and all the guides I can see are for US cars with cruise control, clutch switches etc.
    So I have a stock 1990 320i, none of the wiring has been modified, there are no clutch switches and no cruise control to worry about.
    Am I right in saying (before I start chopping up wires and splicing haha!) that all I need to do to over ride the automatics neutral gear start inhibitor is the below taken from a very old ''Waybackmachine'' archive I have found? Do I even need to do the ''disconnect C143'' stage if I don't have cruise control?
    Thanks very much in advance!
    ''All that needs to be done is to splice the GRN/YL and the two GRN/BLK wires together, tape back the BLU/WHT and BRN/BLK wires, splice the C301 side of the GRN/YL wire to the GRN/WHT wire from the other side of C301, connect your reverse light harness from the trans to C301, and disconnect C143 under the dash. That's it.
  • Panici
    • Dec 2009
    • 2527
    It might be different with the euro harness, but I was able to completely remove the Automatic add-on harness without any cutting or splicing. Car is now wired like a factory 5-speed.
    This link may be useful to you:
