How to remove oil fill plug on Getrag 260 with long tube headers?
  • TrentW
    • 2815
    So I wanted to change out my trans fluid, but with IE long tube headers they really make it very difficult to remove the fill plug. I can't even get a wrench on the plug. Anyone have a solution?
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Are you using the BMW specific wrench for the transmission or are using something else?
    https://www.pelicanparts.com/More_In...=c&SVSVSI=0123
    How much room do you have exactly?
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • TrentW
      • 2815
      ​ I don't have a pic, but hopefully this one will give you an idea of how tight the space is. You need to get your wrench up between the collectors and then get the allen fitting in the plug and turn it out. That wrench you posted looks like it may not be long enough, as you can only get the wrench up so high. Plus, I'm going to change out the plug with one that has a male fitting, then use my new flex head wrench and socket to see
      how that works. ​​​​​​​
      The difficulty with using this wrench is that you need to keep the wrench at the correct angle to keep the fitting in the plug recess. The wrench you posted looks like it may be at a slight angle, and this would be a def benefit. Going to order it and see if I can make it work.
      • uturn
        • Dec 2010
        • 1006
        I don't have that pelican wrench but I have a zero offset XL box wrench and hex socket that I set up similar to it. Plenty of reach and leverage.
