G260 selector rod shaft seal install
  • aavani90
    • Oct 2020
    • 111
    Tackling a leak on my G260 for the first time. Selector shaft seal is leaking bad, after about 20 mins of convincing it I finally got it out. My new seal is a different manufacturer than the one I removed so I can’t tell which direction to install it. I’ve attached “photo A” and “photo B” if anyone can help me out. Also, do I need to oil/grease the new seal when installing it?
    New seal is Elring: 327.299
    89’ 325i Coupe Schwarz
    89’ 325i Cabrio Alpine Weiss II
    90’ 325is Schwarz
  • tomstin
    • Mar 2015
    • 571
    Try this, roughly 9 minute mark https://www.youtube.com/watch?v=13_wcqmsgrQ
    " How to Replace Gearbox Seals | BMW E30 | Getrag 260 + SHIFTER OVERHAUL"
    2004 525i Manual - 1985 325E Coupe Manual
    • aavani90
      • Oct 2020
      • 111
      I’ve watched that same video probably 20 times since yesterday. It doesn’t really show what direction he puts it in. Thank you though, I appreciate it.
      90’ 325is Schwarz
      • Panici
        • Dec 2009
        • 2560
        Your photo A and B don't show up for me.
        Yes, lube it up with some oil.
        Originally posted by uturn
        This is the outside face of the seal....you can read the numbers... what you should see after you install it.
        Here is a picture from 2015 where I installed an OEM BMW seal on my G260.
        2015-06-18 15.22.12 by Panici, on Flickr
        • aavani90
          • Oct 2020
          • 111
          Im having trouble with uploading the pictures. Let me know if this works
          90’ 325is Schwarz
          • aavani90
            • Oct 2020
            • 111
            90’ 325is Schwarz
            • uturn
              • Dec 2010
              • 1006
              • Panici
                • Dec 2009
                • 2560
                Much better wording, thank you. This is correct.
                OP your photo "B" is correct.
                • aavani90
                  • Oct 2020
                  • 111
                  I installed it yesterday and it went in smooth, I put it in as shown in photo B. No more leaks and it seems to have tightened up some of the play in the DSSR. Thank you all!
                  90’ 325is Schwarz
                  • Panici
                    • Dec 2009
                    • 2560
                    Glad to hear it went well for you. Thanks for checking back in.
