Auto to 5speed Transmission Conversion Write up(56k no
    • 34839
    #76
    I can't help you, but god does driving in Atlanta during rush hour suck!!!
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      #77
      Originally posted by delatlanta1281
      Ok
      From the beginning.
      Car = 1990 325 IS
      Tranny = 1988 325 I vert.
      Clutch = single mass
      Flywheel + single mass
      New master
      New disc
      New Slave
      New bushings
      Pedals done with helper spring adjusted
      Wiring complete
      3/4 of an inch of travel for slave cylinder.
      System bled completly
      Symptoms.
      Car goes into gear with no problem when off.
      When on it "clicks" into gear with the brake on.
      With the brake off and pedal to the floor it rolls in 1st, 2nd, and reverse.
      the release is right for an e30, but the disengage doesn't happen halfway down the throw like mine or any other I have driven.
      Possibilities in my eyes are....
      Fork is worn. (not too likely)
      Wrong clutch disk?
      Other than that I am at a loss.
      The car is "driveable" but it seems the longer you mess with it while running the harder it is to get in gear. We reverse bled the system with a syringe from the bottom up. we pushed fluid through the system five to six times.
      we centered everything but didn't use a centering tool, the trans was greased and slid in like a dream.
      Throwout bearing is the right number and meets Bentley's specs as does the flywheel.
      That's it, I am at a loss. My buddy is actually driving my e30 (our third car) 30 miles every day since this started. While he is one of my best friends, if you guys understand the traffic in Atlanta it's really only a matter of time before "crunch"! So...... yeah.
      Sounds like you did what I did the first time I did this swap and installed the wrong clutch kit. I originally installed a clutch kit for a car that has a dual mass flywheel on a single mass "i" flywheel. The difference is that the single mass pressure plate is slightly thicker by like a quarter to a half inch.
      If you have a dual mass pressure plate on a single mass flywheel then the pivot arm has to reach further to disengage the clutch disc if it will even reach at all.
      • delatlanta1281
        Dart Master
        • Mar 2006
        • 10317
        #78
        Got it figured out! It was a faulty pressure plate. Replaced it and it is as good as .......... new.... or something.
        Yours truly,
        Rich
        you kids get off my lawn.....
        • PУCCKAЯ_e30ka
          • Jan 2006
          • 1226
          #79
          what are the seals on tranny itself that CAN be replaced? I'll go to realoem and check.. but if anybody can list off of top of their head!
          • 92 mtechnic cabrio
            • 4907
            #80
            Input shaft seal
            Output shaft seal
            Shift Detent Plate
            Shift selector seal
            R.I.P 07/01/09 - 04/23/10 :(
            • Maluco
              • Oct 2005
              • 6572
              #81
              I have:
              Tranny - no linkage(s)/lever
              Drive Shaft
              Brake Booster
              Pedal Box
              Clutch Kit
              Slave Cylinder
              Hoses
              What else besides the below am I lacking? (do you have a flywheel?)
              5spd Radiator
              flywheel
              tranny shift linkages/lever
              tranny mount and isolators
              starter?
              guibo?
              Somebody help me finally get my list right! Then I can start worrying on actually getting it done. I have the money finally!
                • 4907
                #82
                Originally posted by Maluco
                I have:
                Drive Shaft
                Brake Booster
                Pedal Box
                Clutch Kit
                Slave Cylinder
                Hoses
                5spd Radiator
                flywheel
                starter?
                guibo?
                you can use the automatic radiator, you can also use the automatic starter
                you'll also need clutch master and accompanying hard line and flex line that goes to slave cylinder.
                you'll need a clutch fork, new pilot bearing, clutch fork pin.
                • Maluco
                  • Oct 2005
                  • 6572
                  #83
                  sweet
                  I think that's the hoses I already have. I guess I'll need a resevoir as well....
                  Does the pilot bearing not come in the clutch kit?
                  • PУCCKAЯ_e30ka
                    • Jan 2006
                    • 1226
                    #84
                    do you just plug the line openings for auto trans in radiator?
                    • Digitalwave
                      is a poseur
                      • 6299
                      #85
                      I just left mine open.
                      RISING EDGE
                      • mattdk318i
                        • Jun 2006
                        • 3953
                        #86
                        Just dont plan on selling the radiator if you part it. Esp for a auto. But i did the same
                        • Digitalwave
                          is a poseur
                          • 6299
                          #87
                          Who would want a 100,000 mile radiator anyways?
                          RISING EDGE
                          • mattdk318i
                            • Jun 2006
                            • 3953
                            #88
                            Youd be surprised. Ive seen people part auto 200k eta's and sell everything off of it
                              • 34839
                              #89
                              haha, the 224k radiator from my parts car was nicer than mine... but it may have been replaced.
                              • PУCCKAЯ_e30ka
                                • Jan 2006
                                • 1226
                                #90
                                if I find a pedal box from '90+ can I just swap the manual in? or it would be easer to transfer the pedals?
