Auto to 5speed Transmission Conversion Write up(56k no
  • shiboujin
    • Feb 2006
    • 2791
    #121
    Here's my version: http://e30performance.info/viewtopic.php?f=22&t=231
    Basic parts:
    Drive shaft $100-150
    Master cylinder $60 (http://www.pelicanparts.com/bmw/cata...pg4.htm#item17)
    Slave cylinder $25
    Transmission $200-300ish
    Clutch and related parts (flywheel, bearings, etc) wildly varies... $200+?
    Clutch lines $30~
    Clutch pedal set $25-50~
    Then the little nick knacks
    • JinormusJ
      • 6887
      #122
      Originally posted by Mahalaleel
      How much would an auto-manual swap cost in parts these days?
      After today's purchase for my flywheel bolts, I'm clocking in at $550 for a full swap plus upgrades. However, I was lucky enough to get half the stuff I needed for free from my main supplier, bless his heart :) (pedal box, master/slave, shift linkage/rod, and clutch fork). The tranny I spent a good $160 on, $50 for the driveshaft, $60 for the hydraulic hard clutch line, $50 for new Guibo, Pilot bearing, and CSB, $60 for a used clutch kit with only 5k miles, $20 for the flywheel, $40 for the bolts, and $110 for a short shift kit and bushing rebuild. Your thinking of spending a good ~$600-$700 if your on a strict budget and only buy neccessities.
      It's definitely doable on a budget; I bought all the main components used, (don't go spending $200+ on just a new flywheel, there are plenty of good used ones), but the maintainence stuff like rubber seals/hydraulic hoses, guibo, and CSB and junk, buy new.
      • Yooliseez
        • Aug 2015
        • 27
        #123
        Anyway to get pictures to work on mobile?
        • LateFan
          • May 2013
          • 4414
          #124
          PM me your email and I'll send a pdf of the Yoshi write-up I saved. Too big to post here.
