Auto to 5speed Transmission Conversion Write up(56k no
  • Marvin
    • Jan 2004
    • 58
    Heres the 5 speed conversion progress/write up so far.
    Year: 1989
    Make: BMW
    Model: 325ic
    Part Lists/Price Guide
    5speed conversion kit i purchased from Dave Adams-92 M-technic for $600
    1- included in $conversion kit
    1- Cross member (Qty 1) Part# 23 71 1 176 574 - $ conversion kit
    2- Rubber mounting (Qty2) Part# 23 71 1 175 939
    3- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
    5- Wave washer (Qty 2) Part# 07 11 9 932 095
    6- Hex nut (Qty 2) Part# 07 11 9 922 856
    7- Square headed bolt (Qty 2) Part# 23 71 1 130 250
    9- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
    1- Torx bolt (Qty 2) Part# 23 00 1 222 890
    2- Torx bolt (Qty 2) Part# 23 00 1 222 893
    3- Flat washer (Qty 4) Part# 07 11 9 931 699
    4- Dowel (Qty 2) Part# 11 11 1 743 118
    5- Torx bolt (Qty 4) Part# 23 00 1 222 887
    6- Wave washer (Qty 4) Part# 07 11 9 932 095
    7- Hex bolt (Qty 1) Part# 07 11 9 913 015
    8- Torx bolt (Qty 2) Part# 23 00 1 222 889
    9- Wave washer (Qty 2) Part# 07 11 9 932 112
    10- Hex nut (Qty 2) Part# 07 12 9 900 812
    1- Pressure plate (Qty 1) Part# 21 21 1 223 026 Cost $56.00 from BMA
    2- Clutch disk (Qty 1) Part# 21 21 1 223 671 Cost $74.00 from BMA
    3- Clutch rel. fork lever (Qty 1) Part# 21 51 1 204 229 Cost $conversion kit
    4- Clutch release bearing (Qty 1) Part# 21 51 1 223 366 Cost $28.50 from BMA
    5- Ball pin (Qty 1) Part# 21 51 1 202 659 Cost $.58 from BMA
    6- Spring clip (Qty 1) Part# 21 51 1 204 327 Cost $1.30 from BMA
    7- Screw fillister head (Qty 6) Part# 07 11 9 919 939
    1- Input cylinder clutch (Qty 1) Part# 21 52 1 156 000
    2- Hex bolt (Qty 2) Part# 07 11 9 913 477
    4- Fit bolt (Qty 1) Part# 21 52 1 151 447
    5- Self-locking hex nut (Qty 1) Part# 0712 9 946 400
    7- Connector (Qty 1) Part# 21 52 1 151 697
    8- Hose (Qty x) Part# 21 52 1 163 714
    9- Grommet (Qty 1) Part# 21 52 1 156 082
    10- Pipe (Qty 1) Part# 34 32 6 755 555
    11- Connector (Qty 2) Part# 34 32 1 151 806
    13- Clip (Qty 1) Part# 34 34 1 163 565
    14- Output cylinder clutch (Qty 1) Part# 21 52 1 116 300
    15- Vent screw (Qty 1) Part# 21 52 1 116 360
    16- Protection cap (Qty 1) Part# 21 52 1 154 976
    17- Knurled bolt (Qty 2) Part# 21 51 1 203 012
    18- Self-locking hex nut (Qty 2) Part# 07 12 9 946 400
    1- Supporting bracket (Qty 1) Part# 35 11 1 157 719
    2- Gasket (Qty 1) Part# 35 11 1 150 370
    3- Self-locking collar nut (Qty 4) Part# 31 33 1 092 887
    4- Flat washer (Qty 2) Part# 24 11 1 690 120
    5- Hex bolt w/washer (Qty 2) Part# 07 11 9 915 160
    6- Stop light switch (Qty 1) Part# 61 31 8 360 420
    7- Brake pedal (Qty 1) Part# 35 21 1 154 729
    8- Rubber pad (Qty 1) Part# 35 21 1 108 634
    9- Bush bearing (Qty 2) Part# 35 21 1 109 541
    10- Spacer sleeve (Qty 1) Part# 35 21 1 150 346
    11- Tension spring (Qt 1) Part# 35 21 1 152 371
    12- Grommet (Qty 2) Part# 35 41 1 113 728
    13- Pin (Qty 1) Part# 34 31 1 152 270
    14- Clamp (Qty 1) Part# 34 33 1 120 538
    15- Clutch pedal (Qty 1) Part# 35 31 1 154 737
    16- Rubber pad (Qty 1) Part# 35 21 1 108 634
    17- Spacer sleeve (Qty 1) Part# 35 31 1 154 734
    18- Grommet (Qty 1) Part# 35 31 1 113 725
    19- Tension spring (Qty 1) Part# 35 21 1 102 383
    20- Cap (Qty 1) Part# 35 31 1 153 896
    21- Stop buffer (Qty 1) Part# 35 31 1 152 237
    22- Compression spring (Qty 1) Part# 35 31 1 151 990
    23- Fit bolt (Qty 1) Part# 35 31 1 150 407
    24- Self locking hex nut (Qty 1) Part# 07 12 9 946 400
    27- Bush bearing (Qty 2) Part# 21 52 1 150 345
    28- Hex bolt (Qty 1) Part# 07 11 9 912 721
    29- Flat washer (Qty 1) Part# 07 11 9 931 020
    30- Self-locking hex nut (Qty 1) Part# 07 12 9 964 672
    CONVERSION BEGINS.....
    Raise up the car and place on jackstands
    Disconnect the transmission accelerator cable from its bracket on the intake manifold and remove it from the throttle operating lever
    Now the removal of the exhaust system. Disconnect the oxygen sensor's electrical connector.
    Remove the exhaust manifold connection nuts (6), exhaust pipe transmission hanger mount, the hanger mount on the rear axle subframe and disconnect the rear muffler (2) mounting clamps.
    Full exhaust system.....fully REMOVED
    Remove the rear reinforcement bar and the exhaust and gas-tank heat shields.
    After removing the heat shields, here's your driveshaft.
    Now removing the selector lever and linkage. Start by removing the console trims.
    Disconnect the electrical switch and remove (2) hex-head screws.
    I removed the entire center console for easy access.
    Now with the exhaust pipes and heat shield out of the way. Remove the retaining clip thats holding the selector rod and lower selector lever.
    Now you can remove the selector lever
    Next, removing the driveshaft.....
    TO BE CONTINUED......
    Marvin
    89 325ic
    89 325i
    03 baby girl
    San Jose, CAlifornia
  • Marvin
    • Jan 2004
    • 58
    First at the sliding coupling, loosen the clamping sleeve by several turns
    Remove the (3) bolts that holds the flexible coupling to the transmission output flange
    Do not pull the bolts yet, this will hold up the front section of the driveshaft
    Now remove the (4) bolts thats holding the rear driveshaft section, but do not pull the driveshaft off
    Bolts are off
    Carefully loosen the (2) bolts thats holding the center section of driveshaft. Now wiggle out the driveshaft careful
    Driveshaft rear section removed
    Driveshaft front section removed
    Yay, Driveshaft finally removed!!!!
    Marvin
    89 325ic
    89 325i
    03 baby girl
    • Marvin
      • Jan 2004
      • 58
      Transmission Removal
      Drain the transmission by removing the ATF sump drain plug
      Remove the ATF filler tube and ATF cooler lines
      Remove the transmission bump stop and the reinforcement plate at the bottom of the bellhousing by removing couple of Torx/Hex bolts
      Working through the opening in the bellhousing, remove the (3)bolts that hold the torque converter to the drive plate
      Support the transmission from below and remove the rear transmission by removing the bolts that hold them to the body. This will lower the rear of the transmission a bit.
      Using long extensions, removed the torx bolts that holds the transmission bellhousing to the engine. Also you need to removed the bolts that hold the starter to the transmission bellhousing.
      Remove the inspection grill from the bottom of the bellhousing for access to the torque converter. Use screwdriver or lever to apply pressure making sure that the torque converter stays firmly mounted to the transmission.
      After removing the transmission off the engine
      Yay!!!! finally got it off...
      TO BE CONTINUED.......
      Marvin
      89 325ic
      89 325i
      03 baby girl
      • Marvin
        • Jan 2004
        • 58
        5 Speed Conversion Part Lists
        Manual and Automatic Parts Comparison:
        Marvin
        89 325ic
        89 325i
        03 baby girl
        • Marvin
          • Jan 2004
          • 58
          Removing Pedal
          Remove the lower trim panels above the brake pedal
          Panel removed
          Disconnect brake light switch connector
          Disconnect the pushrod from the brake pedal by disconnecting the brake pedal return spring, prying off the retaining clip, and sliding out the clevis pin.
          Retaining clip and clevis pin removed
          Remove vacuum booster mounting nuts (4) and remove (2) bolts by the top of the pedal
          Now carefully pull out the pedal..
          Pedals from a manual transmission w/ airbag needs to be modified. The top part of the pedal needs to be shorten.
          TO BE CONTINUED........
          Marvin
          89 325ic
          89 325i
          03 baby girl
          • Marvin
            • Jan 2004
            • 58
            Originally posted by PanamaE30
            Originally posted by Marvin
            Are you using a Getrag 260? I've got this weird issue where my tranny is leaning to the left, and I've been suspecting the mounts and brace...
            Could you do me a big favor and compare lean angles on the two crossmembers? I have the feeling that my tranny got swapped (because my car was originally automatic) and that they used the auto tranny with some modification. That's something I've wanted to fix for a while...
            Yes, i'll be using Getrag 260
            Hers a pic of the transmission mounts....
            Marvin
            89 325ic
            89 325i
            03 baby girl
            • Marvin
              • Jan 2004
              • 58
              Regarding the problem im having with the pedal assembly. After 6 beers (Corona) I started thinking to how can i solve the problem. Then it hits me. Why not just swap the bracket thats holding the pedals. As you can see on the pics. The pedal assembly from 92 M-technic w/ airbag mounting bracket is much longer than the auto's pedal assembly. THIS WILL NOT WORK!!!!....The pedal bracket from the auto doesnt have the lip (spring guide) which the compression spring (clutch pedal over-center helper spring) sits....
              all that needs to change is to remove the pedal shaft bolt & transfer just the manual pedals over to the automatic bracket
              Here's a pic after swaping the manual pedals to the automatic bracket.
              Marvin
              89 325ic
              89 325i
              03 baby girl
              • Marvin
                • Jan 2004
                • 58
                some parts that i ordered for the conversion is in back order.
                probably not until after the holiday.
                Sorry for the slow progress......
                Marvin
                89 325ic
                89 325i
                03 baby girl
                • Marvin
                  • Jan 2004
                  • 58
                  just came back from my 2weeks vacation....
                  heres some more parts for the conversion.
                  Removing the flywheel. When removing the mounting bolts, hold the ring gear stationary using a holding fixture. I actually used an electric impact wrench to remove the bolts.
                  After removing the flywheel
                  Heres a pic of the transmission
                  Also installed a new clutch slave cylinder.
                  To be continued.....
                  Marvin
                  89 325ic
                  89 325i
                  03 baby girl
                  • Marvin
                    • Jan 2004
                    • 58
                    Sorry for the slow progress. Just came back from my long vacation.
                    Well, here it is again,
                    Installing the flywheel and Clutch.
                    I purchased new flywheel bolts and coated the threads with Loctite
                    Now its time to reinstall the flywheel. After the long vacation, the flywheel started to rust, so i slightly sanded it down to remove the rust.
                    You must use a torque wrench and a flywheel lock to tighten the flywheel. Also tighten the bolts in sequence alternating between opposite sides fo the flywheel
                    Shows the flywheel installed with all the bolts properly tightened to the proper torque.
                    Clutch alignment tool
                    I started installing the clutch disc and the pressure plate onto the flywheel and realize that i forgot to get new pressure plate bolts. so i guess....
                    TO BE CONTINUE......
                    Marvin
                    89 325ic
                    89 325i
                    03 baby girl
                    • Marvin
                      • Jan 2004
                      • 58
                      With the flywheel mounted, take your clutch alignment tool and place it in the center of the pilot bearing. Install the clutch disc
                      Then install the pressure plate onto the flywheel, compressing the clutch disc
                      Use new pressure plate mounting bolts
                      Tighten the pressure plate mounting bolts evenly until the clutch disc is firmly held in place.
                      Tightened pressure plate bolts down to its proper torque, then remove the alignment tool.
                      Pic after the clutch assembly installed
                      Now on the pedal assembly
                      Installing clutch master cylinder
                      Pic after installing clutch master cylinder
                      Test fitting
                      Marvin
                      89 325ic
                      89 325i
                      03 baby girl
                      • Digitalwave
                        is a poseur
                        • 6287
                        Originally posted by e30 gangsta
                        hhaha well i just got back form dropping my auto tranny out. I have 1 question though.. where i can i get this metal line that is shown here???? any part #/ info would help.
                        It's easier to use a used one since it needs to be bent. The parts car didn't have one?
                        RISING EDGE
                        • Marvin
                          • Jan 2004
                          • 58
                          part # 34 32 6 755 555
                          Marvin
                          89 325ic
                          89 325i
                          03 baby girl
                          • Bryson
                            • 1490
                            both lines can be unbolted from the radiator with no ill effects. They have to be snaked out from underneath the car unless you remove things in the engine compartment
                            • Marvin
                              • Jan 2004
                              • 58
                              Removing the the (2) transmission lines
                              Shows how the lines are attached to the front transmission cooler, which is located in front of the engine radiator (shows the upper line)
                              (shows the lower line)
                              Loosen using the correct wrench. You should be able to pull the lines out of the connector.
                              The line can then be snaked out and around the suspension for removal. Pic of the transmission line after removing.
                              Shift coupler
                              Mount the coupler on the transmission and tap in the pin that secures it to the selector shaft. Make sure that you place the small retaining clip on the selector shaft prior to tapping in the pin.
                              When the pin is tapped in, move the retaining clip to cover.
                              Now the Transmission...
                              Lightly lubricate the clutch disc splines and the transmission input shaft splines
                              Also grease up this rubber piece
                              Install the throw-out fork. The fork is attached at one end with a small metal clip.
                              Use grease to pact the release bearing lubricating groove and to coat the guides.
                              Install the release bearing
                              Pics after everything assembled
                              Marvin
                              89 325ic
                              89 325i
                              03 baby girl
