Auto to 5speed Transmission Conversion Write up(56k no
  • shiboujin
    • Feb 2006
    • 2791
    #106
    Thanks!!!!!!!!!!!!
    • evil_twin
      • Nov 2007
      • 2965
      #107
      TwoJ's! thanks soo much!
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • TwoJ's
        • Oct 2005
        • 4908
        #108
        No problem. I will be needing to do this in the near future, and I figured it would help a lot. On top of that, it'll now be easier for me to find again.
        • shiboujin
          • Feb 2006
          • 2791
          #109
          Hopefully my write up should be stickied so you should just have to point ppl to that :-p
          • Teaguer
            • Sep 2004
            • 6167
            #110
            Lame .
            • The Barvarian
              • 162
              #111
              No pictures?
              "Life's Journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...Holy S**t!! What a Ride!!"
              • shiboujin
                • Feb 2006
                • 2791
                #112
                • JiX
                  • May 2007
                  • 53
                  #113
                  Originally posted by Marvin
                  Heres the 5 speed conversion progress/write up so far.
                  Part Lists/Price Guide
                  5speed conversion kit i purchased from Dave Adams-92 M-technic for $600
                  1- included in $conversion kit
                  1- Cross member (Qty 1) Part# 23 71 1 176 574 - $ conversion kit
                  2- Rubber mounting (Qty2) Part# 23 71 1 175 939
                  3- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
                  5- Wave washer (Qty 2) Part# 07 11 9 932 095
                  6- Hex nut (Qty 2) Part# 07 11 9 922 856
                  7- Square headed bolt (Qty 2) Part# 23 71 1 130 250
                  9- Hex nut w/plate (Qty 2) Part# 23 71 1 130 253
                  1- Torx bolt (Qty 2) Part# 23 00 1 222 890
                  2- Torx bolt (Qty 2) Part# 23 00 1 222 893
                  3- Flat washer (Qty 4) Part# 07 11 9 931 699
                  4- Dowel (Qty 2) Part# 11 11 1 743 118
                  5- Torx bolt (Qty 4) Part# 23 00 1 222 887
                  6- Wave washer (Qty 4) Part# 07 11 9 932 095
                  7- Hex bolt (Qty 1) Part# 07 11 9 913 015
                  8- Torx bolt (Qty 2) Part# 23 00 1 222 889
                  9- Wave washer (Qty 2) Part# 07 11 9 932 112
                  10- Hex nut (Qty 2) Part# 07 12 9 900 812
                  1- Pressure plate (Qty 1) Part# 21 21 1 223 026 Cost $56.00 from BMA
                  2- Clutch disk (Qty 1) Part# 21 21 1 223 671 Cost $74.00 from BMA
                  3- Clutch rel. fork lever (Qty 1) Part# 21 51 1 204 229 Cost $conversion kit
                  4- Clutch release bearing (Qty 1) Part# 21 51 1 223 366 Cost $28.50 from BMA
                  5- Ball pin (Qty 1) Part# 21 51 1 202 659 Cost $.58 from BMA
                  6- Spring clip (Qty 1) Part# 21 51 1 204 327 Cost $1.30 from BMA
                  7- Screw fillister head (Qty 6) Part# 07 11 9 919 939
                  1- Input cylinder clutch (Qty 1) Part# 21 52 1 156 000
                  2- Hex bolt (Qty 2) Part# 07 11 9 913 477
                  4- Fit bolt (Qty 1) Part# 21 52 1 151 447
                  5- Self-locking hex nut (Qty 1) Part# 0712 9 946 400
                  7- Connector (Qty 1) Part# 21 52 1 151 697
                  8- Hose (Qty x) Part# 21 52 1 163 714
                  9- Grommet (Qty 1) Part# 21 52 1 156 082
                  10- Pipe (Qty 1) Part# 34 32 6 755 555
                  11- Connector (Qty 2) Part# 34 32 1 151 806
                  13- Clip (Qty 1) Part# 34 34 1 163 565
                  14- Output cylinder clutch (Qty 1) Part# 21 52 1 116 300
                  15- Vent screw (Qty 1) Part# 21 52 1 116 360
                  16- Protection cap (Qty 1) Part# 21 52 1 154 976
                  17- Knurled bolt (Qty 2) Part# 21 51 1 203 012
                  18- Self-locking hex nut (Qty 2) Part# 07 12 9 946 400
                  1- Supporting bracket (Qty 1) Part# 35 11 1 157 719
                  2- Gasket (Qty 1) Part# 35 11 1 150 370
                  3- Self-locking collar nut (Qty 4) Part# 31 33 1 092 887
                  4- Flat washer (Qty 2) Part# 24 11 1 690 120
                  5- Hex bolt w/washer (Qty 2) Part# 07 11 9 915 160
                  6- Stop light switch (Qty 1) Part# 61 31 8 360 420
                  7- Brake pedal (Qty 1) Part# 35 21 1 154 729
                  8- Rubber pad (Qty 1) Part# 35 21 1 108 634
                  9- Bush bearing (Qty 2) Part# 35 21 1 109 541
                  10- Spacer sleeve (Qty 1) Part# 35 21 1 150 346
                  11- Tension spring (Qt 1) Part# 35 21 1 152 371
                  12- Grommet (Qty 2) Part# 35 41 1 113 728
                  13- Pin (Qty 1) Part# 34 31 1 152 270
                  14- Clamp (Qty 1) Part# 34 33 1 120 538
                  15- Clutch pedal (Qty 1) Part# 35 31 1 154 737
                  16- Rubber pad (Qty 1) Part# 35 21 1 108 634
                  17- Spacer sleeve (Qty 1) Part# 35 31 1 154 734
                  18- Grommet (Qty 1) Part# 35 31 1 113 725
                  19- Tension spring (Qty 1) Part# 35 21 1 102 383
                  20- Cap (Qty 1) Part# 35 31 1 153 896
                  21- Stop buffer (Qty 1) Part# 35 31 1 152 237
                  22- Compression spring (Qty 1) Part# 35 31 1 151 990
                  23- Fit bolt (Qty 1) Part# 35 31 1 150 407
                  24- Self locking hex nut (Qty 1) Part# 07 12 9 946 400
                  27- Bush bearing (Qty 2) Part# 21 52 1 150 345
                  28- Hex bolt (Qty 1) Part# 07 11 9 912 721
                  29- Flat washer (Qty 1) Part# 07 11 9 931 020
                  30- Self-locking hex nut (Qty 1) Part# 07 12 9 964 672
                  600 bucks includes everything needed for the swap?
                  • Digitalwave
                    is a poseur
                    • 6302
                    #114
                    I wish it was $600... I spent over $1,500 on mine.
                    RISING EDGE
                      • 34847
                      #115
                      it depends on how many "extras" you do along the way - I spent more on mine, but I replaced a lot of other stuff at the same time.
                      • IminDiegoTriick
                        • Oct 2009
                        • 1564
                        #116
                        Im about to do this. I need pictures :P
                        Fast life fuck slow..Low life for life
                        Let the mix flow..Let the night flow
                        I'm so gone ✗ ♥ O
                        • shiboujin
                          • Feb 2006
                          • 2791
                          #117
                          • IminDiegoTriick
                            • Oct 2009
                            • 1564
                            #118
                            thank you!!
                            I'm so gone ✗ ♥ O
                            • pmac
                              • 24
                              #119
                              Thanks!
                              • Mahalaleel
                                • 181
                                #120
                                This thread is awesome. Any way to restore the OP pics?
                                Either way, I just realized this thread is ancient. How much would an auto-manual swap cost in parts these days?
