What is needed to swap small case diff to med case diff?
  • FetusGoulash
    • Apr 2009
    • 91
    My 85 318 has a small case diff and i am looking to upgrade to an LSD unit from a 325is. From what i have read that diff is a medium case. I searched but found no definite answer to my question
    Is it as easy as just swapping the diffs or do i need other parts? such as the axle shafts from the medium case? If so would the output flanges on the diff be interchangable meaning i could use the flanges from my small case to run my stock axles?
    thanks
  • Aptyp
    • 6584
    you need diff and axles
    • FetusGoulash
      • Apr 2009
      • 91
      Ok so with the axles do i also need the rear hubs from said car? will the axles have a different sized outer joint where the mate with the hubs?
      Oh and my car has drum brakes, the 325 having disc would that make a difference?
      • reelizmpro
        • 9559
        If I remember correctly, you need nothing. The small 318i diff just has longer flanges to make up the difference. The 325 diff should bolt and fit right in.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • FetusGoulash
          • Apr 2009
          • 91
          That is what i wanted to hear! anyone else back this up?
          • xwill112x
            • Jan 2009
            • 4236
            no you dont.
            the medium case will swap directly in. you dont need the 325 axles.
            i speak from experience.
            • REVHARD05
              • Sep 2005
              • 250
              i 2nd it swaps right in
