Question regarding 24v swap/shifter rods
  • dsobering47
    • Oct 2007
    • 697
    I have a 1991 318is body, with no engine/trans. I'll be purchasing a S52 with the ZF320, and my question is what shift rod/holder/carrier do I need? Should I try to source one for an E30, if so which one? Should I just get everything E36 related? I literally have nothing and I'm having a hard time finding this info.
    Thanks
  • FredK
    • 14762
    I've used the S52 stuff in its entirety, except the rear console mounting bushing, which I used an E30 unit. I used a E36 shift console, selector rod, and console spring clip.
    • dsobering47
      • Oct 2007
      • 697
      Did you use OEM E36 stuff, or have you upgraded any portion of the shifting system? You're saying just use all E36, save for the rear console mounting bushing?
      • FredK
        • 14762
        Yes, I just used OEM E36 stuff, though I bought a new nylon shift cup, selector rod bearing (that attaches to the transmission), and shift lever.
        • dsobering47
          • Oct 2007
          • 697
          Right on. Thanks for the info, I appreciate it.
          • ForcedFirebird
            • Feb 2007
            • 8300
            I used the zf rod/shifter on a Getrag 260 behind a m50 (long story), so I am guessing that the e30 shifter should work the other way 'round.
            john@m20guru.com
            Links:
