High lock diffs
  • u3b3rg33k
    • Jan 2010
    • 2452
    #76
    Originally posted by JakeP
    But this isn't oil. And there isn't anything wearing/rubbing, is there?
    Just because it's a liquid doesn't mean it can't change state.
    Take a butter churn as an example. I don't see any friction, but it still turns milk into butter. Look into shear forces in fluids - that has an effect on molecules.
    Heck, i just found your friction. Molecules rubbing on molecules.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
    • JakeP
      • 315
      #77
      Well, if any of you come across a 3.91 viscous diff out of a manual IX, shoot me a PM and I'll try it in my car and the drift car.
      • Wanganstyle
        • 2828
        #78
        you should try to shim it before install, if you drift it as is it may die very quickly....
        VLSD hates drifting :) but we do it anyway!!!
        • 328ijunkie
          • May 2007
          • 3961
          #79
          My customer diff building pictures for all to enjoy:
          Check Us out on Facebook
          Full Product Line Tuning
          • Jean
            • 18228
            #80
            4 new oem clutch discs have been ordered overnight :) If all goes as I planned I'll have my center section out this friday/saturday for a build.
            • shiboujin
              • Feb 2006
              • 2791
              #81
              Just remember, don't just shove in extra clutches. You need to machine if you go more than 3 clutches. Otherwise, you might as well just weld the damn thing.
              • Jean
                • 18228
                #82
                I'll leave that to the pro to do :)
                • FredK
                  • 14739
                  #83
                  Are you getting new ramps cut?
                  • samiam3356
                    • Jul 2009
                    • 1901
                    #84
                    ^^Thinking of doing this on my next rebuild. Want to add at least on more clutch and might go up to the 2.1mm plates.
                    Originally posted by Roysneon
                    $5 shipped?
                    Originally posted by MarkD
                    You are a strange dude, I'n not answering any more posts from you.
                    • Jean
                      • 18228
                      #85
                      Not doing different ramps at this time, it adds up another $$$ on top and I don't want to make too many changes at once to evaluate the results...
                      • FredK
                        • 14739
                        #86
                        Sure. So you'll have a 75% lock diff?
                        • guibo09
                          • Dec 2008
                          • 834
                          #87
                          this thread makes me happy i took the time to swap a z3 lsd into a 4.11 pumpkin.
                          90 E30 325i
                          • Wanganstyle
                            • 2828
                            #88
                            Where do you know this from? I have a 4 disc in my car, no machining required. You can drive it if you are local
                            • Ian Bowers
                              • Apr 2008
                              • 1120
                              #89
                              I just wanted to update: I purchased 3 Bimmerworld "race" clutch discs, and an extra porsche 2.0mm plate. My bud put it together and modified the ramp angle so it's around 60-65% lockup.
                              It's. Fucking. Amazing. It honestly changed the way the car drove. It is more predictable, more stable, and much more communicative. I love it.
                              • Wanganstyle
                                • 2828
                                #90
                                YUPS. my E30 does a throttle induced doughnut or 2 every time I need to change directions on my street now........addicting.....
