Hard to get into first gear
  • kencopperwheat
    King of Kegstands
    • 14396
    Originally posted by Schneider325
    it takes 2 hands to get into reverse... is that just me being weak or is that normal?
    Either you're REALLY weak, or your bushings and shit are really worn out.
    Originally posted by Gruelius
    • AndrewBird
      The Mad Scientist
      • 11898
      Double clutching is a lot like rev-matching, but instead of just reving the engine to match the rpms while letting the clutch out, you let the clutch out with the car in neutral, match the revs to the gear you are going into and then depress the clutch and slide it into gear. Pretty complicated and hard to do unless you have LOTS of practise. IMHO, not worth it unless you are racing on a track or have a REALLY bad tranny or something.
      • erik325i
        • Jan 2005
        • 3567
        Yeah, double clutching is needed when the tranny doesn't have synchros, or the synchros die (like most MGs). I wouldn't do it unless I had to.
        • Bryson
          • 1490
          if you want to get into first at speed...
          • NC325iC
            • Mar 2004
            • 6565
            if your goin above like 2mph then 2nd will suit you just fine
            • Bryson
              • 1490
              hahaha, not with an s14/m10
              • AndrewBird
                The Mad Scientist
                • 11898
                Actually, MG transmission are pretty much bullit proof, asuming you are not talking about the overdrive unit. Mine has over 140,000 miles on it and still shifts and runs smoothly.
                • erik325i
                  • Jan 2005
                  • 3567
                  That's the first time I heard of MG trannys being bullit proof. Most MGBs I've seen require to double clutch each shift because of blown synchros. I was suprised when my friend's dad got an MGB that had working synchros (except first gear). It was rebuilt earlier though.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    Really? I have never heard of the synchros going bad in them. Huh, weird.
                    • nickmp0wer
                      • 1427
                      my dad has an old tc or something like that. Theres no way he knows what double clutching is so they must be fine
