Cost of switching to an automatic?
  • viCe
    • Jul 2005
    • 1
    I have a 1987 325es with a 5speed. I was curious if anyone has ever done a 5speed => automatic transmission install. I live in a high traffic area and a 5speed does not suit my needs anymore.
    How much does a used auto tranny go for? I can only assume there is a bunch of them since the 5speed is more sought after.
    How much does installation cost? Is a tranny switch very hard/time consuming for a shop to do?
    Should I try and get a rebuilt automatic tranny, or go with one that was pulled straight from the car(like off ebay).
    TIA guys. :D
  • T.Dot E30
    • Mar 2004
    • 536
    where are u located?
    • Justin B
      Sikky Nar Nar
      • Mar 2005
      • 4273
      Arent auto trannies a little larger diameter? Or is that just 2002's that I know of? I think it would be easier to switch from an auto to a 5 speed rather than the other way around. Get another e30 or deal with it? I see what you're getting at but it sounds like a pain in the ass to do. Then again ive never done it and only have minimal knowledge of putting a 5 speed where an auto was... :?
      • Sean
        • 5793
        You'll also need the radiator from an auto car, because it cools the automatic tranny too.
        - Sean Hayes
        • Bimmerfanatik
          • May 2004
          • 5349
          Make a post in the WTB/FS section asking anyone who has an automatic relatively close to you who's willing to swap even. There's enough auto guys out there that would kill for a manual tranny, and since it'd only cost them their auto stuff, why not? You both win, no money is exchanged, and everyone goes away happy.
          • erik325i
            • Jan 2005
            • 3567
            Don't wast your time swapping to an automatic tranny. Just sell your e30 and buy one with an automatic.
            Around me, the auto e30s are cheaper, and in better condition with less miles. That would probably be your best bet. After getting rid of your eta you could even get an "i". Just my opinion.
              • 34847
              I agree, there are too many little things like the tranny kick down, wiring, tranny coolers etc to mess with. it would probably be easier and cheaper to just get another car I think.
              • Digitalwave
                is a poseur
                • 6302
                Yeah, save the trouble and buy an auto car. You need more parts to do the swap to auto than auto to manual. I am not sure but I don't think you could use the 5 speed ECU. You'd need the radiator.
                RISING EDGE
                • James Crivellone
                  Head Janitor
                  • 6305
                  As everybody else said, it would be easier to just buy an auto.
                  However, here are the parts that you would need.
                  ZF Automatic Transmission
                  Automatic Flywheel (as you have an ETA you need an ETA one)
                  Torque Converter
                  Automatic Transmission Radiator (to replace your current radiator)
                  Auto Tranny cooling lines + brackets
                  Auto Tranny Cable feed that goes to your throttle
                  Automatic Driveshaft (date matched with transmission if you want this easy)
                  Don't need new pedals unless you want the wide brake pedal
                  Auto Tranny shifting assembly, which bolts right up where the stick is.
                  Don't need a new ECU
                  Some wiring for the reverse light, and P/N Starter engage
                  and finally, a chip, because auto eta's suck ass ;)
