low idle in drive
  • rede30
    • 4697
    low idle in drive
    I have a little automatic that I have been cruising around. it runs fine and idles fine when in Park but when it is in gear and stopped it idles a little too low. Any ideas?
  • LJ851
    • 7919
    Install the missing third pedal.
    Lorin
    The M30 is God's engine.
    • Jafxod
      • May 2011
      • 1301
      Originally posted by lj851
      install the missing third pedal.
      +1
      • rede30
        • 4697
        maybe if it wasn't an ix. too much work.
          • 34839
          ix is less work. unbolt auto trans, put in clutch, master and pedals. bolt manual trans back in.
          anyway, a low idle in drive could be a misadjusted TPS, vac leaks, dirty/non functioning ICV, etc. I'm sure jlevie will chime in about smoke tests, or you could do a search..
          • rede30
            • 4697
            I don't see how it is less work, maybe equal but then there is the whole finding awd 5spd trans/t-case. Whatever the case, no swap will be happening. ICV was tested in a different m20. I will test the tps tomorrow. It does it hot or cold.
            • xwill112x
              • Jan 2009
              • 4236
              Maybe over expectations..? most auto cars dip down in rpms when at a stop in D.
              • rede30
                • 4697
                yeah, they dip but it is a little too low, at least it feels like it. I had a different auto a few weeks ago and I didn't notice anything. It does idle rock solid when in park.
                • bmwstephen
                  • 2463
                  How low r we talking about here?
                  • rede30
                    • 4697
                    Between 500 and 600.
                    • bmwstephen
                      • 2463
                      Normal on my car as well
                      • mr.vang
                        • 4371
                        that sounds right..
                          • 34839
                          Originally posted by mr.vang
                          that sounds right..
                          no it's not. the factory idle is 750 +/- 50rpm. if that's normal, your car is broken. if you put it in drive, the ECU will compensate by opening up the ICV a bit more, the idle shouldn't change and 500-600 is never "normal".
                          • rede30
                            • 4697
                            What else does the ecu do to compensate? If it is just the icv I should revisit that.
                              • 34839
                              it also adjusts timing to compensate for small changes in idle speed but it's not really directly related to the auto trans. there's no communication that tells the ECU what gear you're in, other than for trying to start the car. That's why it doesn't matter what ECU you have when you do a manual/auto swap.
                              basically the ICV can open far enough to idle the car at ~2500rpm. putting it in gear doesn't add enough load that the ICV can't compensate for on it's own. therefore, if it's idling 150-250 rpm lower than it's supposed to, something is not right with the idle control system.
