low idle in drive
  • mr.vang
    • 4371
    Originally posted by nando
    no it's not. the factory idle is 750 +/- 50rpm. if that's normal, your car is broken. if you put it in drive, the ECU will compensate by opening up the ICV a bit more, the idle shouldn't change and 500-600 is never "normal".
    its normal for a 20 years old car.
      • 34844
      if yours is a total pile of shit? Yes. If it's running correctly? No.
      • LJ851
        • 7919
        When my 89 was auto tragic the idle speed was the same in neutral as it was drive. This on 20+ years old car nearing 200k miles. It also stayed the same if you turned on the A/C. Those tricky germans!
        Lorin
        The M30 is God's engine.
        • rede30
          • 4697
          figured it out. I tossed in a 173 DME and it is perfect.
