1 piece vs 2 piece driveshafts
  • Jean
    • 18228
    Pros/Cons of each?
    Under what specific conditions is one better than the other?
    Thanks
  • Doughnut
    • Oct 2007
    • 869
    Bump.
    I'm interested aswell.
    ///Monstrosity. (OO≡≡[][]≡≡OO)
    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
    • Bearmw
      • 1323
      Wondering also. Ford Rangers used both at different times.
      • KenC
        King of Kegstands
        • 14396
        Installing a one-piece would be difficult, no?
        Originally posted by Gruelius
        • dj01540i6sp
          • Jan 2009
          • 349
          Try it, Give us feed back! Shouldn't be hard for a Drive shaft Welding and Balancing shop to do this. GL
          • Sagaris
            • Sep 2009
            • 2243
            A one-piece drive shaft eliminates the center support bearing and would increase the load on the differential input bearings and the transmission output bearings which could increase their wear rate.
            A two-piece is beneficial for off-roaders since the front shaft remains horizontal and the rear shaft is the one that runs the risk of hitting rocks
            There is more torsional deflection (twist) in a one-piece drive shaft. Out of two similarly spec'd shafts, the two-piece shaft can handle more torque. A one-piece drive shaft is more likely to hit its critical speed which causes it to fail catastrophically.
            Those are just the theoretical problems that you may encounter. You just might install a one-piece drive shaft on your car and have absolutely no issues.
            • DTM190
              • Nov 2008
              • 1107
              I have one in my V8 E30 in my sig.
              Downside is if I ever have to remove gearbox I will need to pull the diff out, or at least move it back, big deal. This is because of having a Toyota gearbox with a slip yoke and not a guido (I know its guibo, I call them guidos) and not being angle to compress the shaft like the E30 2pc.
              Sag, you mention a 2pc can handle more torque? I know of PLENTY of 1000hp+ cars running 1 pc.
              If they are
              1. made from a decent thickness and diameter
              2. built with decent unis
              3. with pinion angle sorted
              4. balanced
              failure is not likely.
              In my experience i have had more probs putting decent power through 2pc, why i went 1pc in that car.
              I saw it as having less issues as the gearbox to diff angle doesnt change like it does in cars with live axle rear ends.
              Just my opinion and no dramas at all with mine.
              Originally posted by der affe
              first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
              if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
              • Dj Buttchug
                • Jun 2010
                • 7688
                one piece drive shaft is better. less parts, less joints means less weight. It wont make your diff wear faster. they work well and are usually very strong.
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • xwill112x
                  • Jan 2009
                  • 4236
                  you could have an aluminum one made a feel a huge improvment..mustang guys do it all the time.
                  • Sagaris
                    • Sep 2009
                    • 2243
                    yes a 2 piece drive shaft can handle more torque than a 1 piece shaft of the same diameter, wall thickness, and material. I made the statement for comparison purposes.
                    I myself am a fan of a lightweight single piece shaft but I haven't run the calculations to see what would fit, if it would vibrate itself to pieces, and how much weight savings there would be
                    • LJ851
                      • 7919
                      For a given length driveshaft, a 2 piece one can be much smaller in diameter and still have a high enough critical speed.
                      Lorin
                      The M30 is God's engine.
                      • Wanganstyle
                        • 2828
                        My RX7 turbo 88 and 93 Twin turbo both had 1 piece Driveshafts; Mazda OEM.
                        I did a manual transmission replacement on my Rx7 Vert once, did not have to remove the diff.
                        1 piece driveshaft never had any failures or nvh or etc..... why? OEM.
                        even the rotary engine was pretty damm reliable. why? It loved me.
                        All nissan 350z's have Carbon fiber/plastic reinforced 1 piece driveshafts. Nissan OEM 1 piece Carbon fiber / plastic Driveshaft; standard spec on every 350z.
                        None of my Z friends have broken or had issues with one of those. The rest of the Z and VQ35 however......
                        In my 2 piece driveshaft experience:
                        Subaru: killed 1 centre bearing.
                        Toyota: Killed one Guibo. those buggers cost like 2x as much as the BMW units.
                        Bmw: killed 2 center bearings, 4 guibos to smithereens.
                        in 3 years of 1 piece driveshaft ownership I had 0 driveshaft issues.
                        these are all OEM applications though, if aftermarket who knows!!
                        • lbreevesii
                          • Aug 2009
                          • 412
                          I'm looking at getting a 1 piece from the drive shaft shop(which happens to be local to me). Aluminum guibo replacement, larger replaceable U joints. Don't have to worry about a failing guibo or csb. All in all I think its worth it.
                          I don't always wreck cars, but when I do I wreck them into trees.
                          91' 318is S50 swap - The Black Widow
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            Every time I drop my heatshield, I see a torn to shit CSB surround.
                            So screw the CSB. if you think there's more wobble on a one piece, how much wobble is there on an unsupported 2 piece? no thank you.
                            I'm gonna do this:
                            unless someone screams "NO! not that brand!"
                            Ich gehöre nicht zur Baader-Meinhof Gruppe
                            Originally posted by Top Gear
                            Just imagine waking up and remembering you're Mexican.
                            Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
