* MODS Can we make this a sticky in this subforum?*
I've noticed through my adventure of replacing my transmission on my 88 325ic that the g260 interchange thread had some pretty incorrect information in it. So I figured I would go ahead and make my own to clear these things up. I will be using the basic layout from that thread but with corrections. I updated that thread but doesn't seem anyone paid attention.
Identify which trans you have early 'eta', late 'eta', or 'i':
1. early 'eta' trans (9/83-4/86)
1. 260.0.1270.90 is on the side of the 'eta' trans
2. shifter mounting about the output flange is only 2xM10 holes for the 84,85,86 style plate mount shifter
3. shallow bellhousing: Slave cylinder mounting flange = 6 1/2
4. 2 drilled holes for crank position sensors
5. smaller output flange
6. you can use part #25112225369 with M8X140 bolts to use the later style shift arms on the early transmissions.
b) late 'eta' trans (5/86-6/88 )
2. shifter mounting about the output flange has 2xM10 holes for the late style shifter and the top ears for the later shift arm.
3. deep bellhousing: Slave cylinder mounting flange = 6 7/8
4. cast boss for 2 drilled holes for crank position sensors, may or may not be drilled
5. larger output flange- can be swapped out with the smaller one with an impact wrench, a deep thin walled 30mm socket. you will need a gear puller to remove it. use red loctite when reinstalling the nut.
6. if you get this one for a 325i, you need part number 21511204525, it is the euro 323i throw out bearing and will make up the difference in the flywheel gap. pelicanparts.com has it for $75
c) 'i' trans
1. 260.0.1346.90 is on the side of the 'i' trans
2. top boss for the aluminum bracket of the 87-91 style shifting mechanism.
4. no cast boss in bellhousing for reference sensors
If you find your 'eta' 260 trans has the deeper bellhousing, you can correct for it by using a thicker throw-out bearing. Sachs P/N 21511204525 is a 30mm bearing and will make up the difference.
If you use the driveshaft/guibo that came with the transmission you'll be fine, the differential end of the driveshaft is the same on all the 6cyl E30s. Or, as stated above, swap out the output flanges on the transmission.
A note on the flywheels:
9/83-4/86 etas: SINGLE MASS Bellhousing depth- 6 1/2
5/86-6/88 etas: DUAL/TWIN MASS Bellhousing depth- 6 7/8
325i: SINGLE MASS Bellhousing depth- 6 1/2
318is m42: dual
And i believe the m10 318's have single.
If you have a transmission from a twin mass flywheel car going on a single mass flywheel car (ie a 5/86+ g260 or a g240 going on a early eta or a 325i) use the 323i throw out bearing.
Also, the 325i bent style shift arm will work fine with the later eta transmission. The eta straight arm will be too long.
If you're thinking about putting a g240 on an m20, it will sit at an angle and be too short to use your 325i parts. You will need a custom driveshift and some sort of shift kit to set off the angle. It will mate up to the engine but be sure to use a dual mass flywheel or the euro throw out bearing.
I will update with the m5x/s5x engines and trans for the swap users later.
I thought I read earlier the e36s etc came with 15mm pilot bearings where e30s came with 12mm? Can anyone confirm?
also, here is a great picture for anyone looking at this to see. the far left is the 323i, middle is 318i, and far right is 325i. notice where the tabs are on each (not my pic):
my 323 t/o bearing wasn't silver when i got it from pelican but it sure as hell was a lot thicker than my brand new 325i one.
this thread here is for an m42 but it gives you the idea on dual mass vs single mass and what transmission or throwout bearing to use: http://www.m42club.com/forums/showthread.php?t=2063
also, i searched the part number for the euro 323i throw out bearing in google and looked for bmw forum threads and found some good info on tranny swaps and dual mass to single mass flywheel swaps which had a lot of relevance to this. i may go through it and paste the links here...or for the time being you can search google.
*i dont mean to offend Jgood or the guy who he got his info from. It was a good start and had some good info in it, but it just wasn't accurate. I felt the need to make this post to use this basic outline of information that Jgood found and correct it with what I just found while doing my transmission swap in July 2011 on my 88 325i using a 88 325(e)/super eta transmission.
--if you feel like you don't like my information, look at one of the most trusted parts sites we use, pelicanparts. here is the link:
http://www.pelicanparts.com/bmw/cata...Tclutc_pg1.htm
(look at the clutch kits and the pressure plates)
c) 'i' trans
318is m42: dual
