getrag 240 Swap
  • Clark954
    • Jun 2011
    • 91
    getrag 240 Swap
    i have an 84 318i 5 spd, and the tran is going out, i was guna rebuild it but i heard that its like the hardest thing to rebuild known on this side of the planet, besides getting another getrag 240 will anything else bolt right into the M10
  • TurboJake
    • 3780
    I beg to differ.
    I think the hardest thing known on this side of the planet to rebuild is a mechanical slot machine.
    Or a swiss watch.
    Leave Me Transaction Feedback
    • Clark954
      • Jun 2011
      • 91
      if i put a swiss watch in the 240 will it work again
      • TurboJake
        • 3780
        Like clockwork.
        • Hey_You
          • Nov 2009
          • 963
          Well...the m10 g240 works with the m30....so most likely the trans behind the m30 will work with an m10? If it fits....well, that's a different issue.
          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
          • jw 325ic
            • Sep 2006
            • 1360
            you can bolt a g240 up to an m20, m30, m50, m42...but it's the matter of the drive shaft fitting.
            OP, i'm not real sure on 318's but i would assume so. search.
            also, Pink Floyd fan?
            • Wanganstyle
              • 2828
              yes, but only if its non-automatic movement. lol
              • Holland
                • Nov 2008
                • 7178
                Early 240's have a different bellhousing pattern. This would be the M10, M30, and S14. The later 240 fits the M42, M20, and M5x
                Originally posted by DEV0 E30
                • bernzpeed
                  • 3917
                  Originally posted by TurboJake
                  I beg to differ.
                  Or a swiss watch.
                  Like clockwork.
                  lol.
                  89 E30 S52
                  Transaction Feedback.
