Just put some it and its reading kind of high on my yellow dipstick. Is it best to take it out?
If I put too much ATF fluid, will I not shift correctly?
auto transmissions are sensitive to fluid level. did you check the fluid after turning the car on, running through the gears and giving it a few minutes to get to operating temp? check fluid while the car is on.
I'd bet it will be just fine, unless it's way overfull. but you have to check with it in neutral and the car running, if it's an auto.Comment
