What would you buy?
  • HighschoolE30
    • Jul 2011
    • 83
    What would you buy?
    Looking to buy a new clutch... Car has a "used" sachs in it and after alittle abuse it feels weak.
    So what do you guys run?
    Suggestions?
    • 37834
    If you're sticking with an OEM style clutch definitely go with Sachs.
    I have a stock Sachs clutch in my turbo E30 with about 10,000 miles on it and it's perfect.
    Grover Beach, California
    BimmerHeads.com
    • ScHpAnKy
      • 1573
      yeah, stock sachs I've seen are good for a few hundred horsepower, you want your clutch to be the fuse, not the half-shafts :P
      with that said, if you are looking for more grab pick up one of those F1/XTR clutches from ebay... I've heard nothing but good things from people with hundreds upon hundreds of ponies under the hood, that's gotta be worth something
      91 318i | 87 535iS
        • 34847
        clutches are rated by torque holding capacity, not horsepower.
        I'd definitely go with sachs. Most of the aftermarket stuff is BS. having a single mass flywheel and an unsprung clutch disk will suck on the street. if you want more torque capacity you can upgrade the pressure plate instead of the friction disk and retain stock like driveability.
          • 37834
          Even a sprung 6 puck clutch isn't too fun, I've got one in my S50 E30. Wish I put a Sachs in that one too, lol.
          BimmerHeads.com
          • HighschoolE30
            • Jul 2011
            • 83
            Thanks for the input guys.
            Sachs is more than likely what ill end up buying. But like every e30, new expenses arise everyday. So i'm not sure when i'll get to buy a clutch.
